Help This cant be right
Discussion in 'Transmission & Driveline Topics' started by boltupal, Jun 12, 2021.
  1. boltupal
    boltupal Veteran Member
    183
    69
    May 21, 2018
    I bought a complete 5 speed Tremec Kit from SST. The clutch pedal is hard , binds and pops. The adjustment rod drops 2 inches from the bell crank lever to the clutch fork. And isnt parallel to the block by 3/4 inch. I tried re contacting SST again via Email. They thumbnail_20210612_083037.jpg thumbnail_20210612_083431.jpg dis abled my account!
  2. DougD
    DougD Veteran Member
    352
    123
    Dec 2, 2014
    Bradenton, FL
    There is a section for trans issues, etc. This one is to discuss issues related to operation of the web site.
  3. Knuckle Dragger
    16,490
    2,817
    Nov 2, 2002
    Waddell AZ
    Moved to transmission section for better visibility.
  4. biker
    biker Veteran Member
    3,775
    1,777
    Dec 7, 2014
    I bought the same kit a few years ago, and originally used it with my stock clutch linkage/zbar setup. Worked great. But, that is not helpful to you..
    So, it sounds more like a linkage/release bearing or pressure plate issue. What do you have for a clutch and pressure plate? Still using stock bell housing?
    Did the trans mate up easily to the face of the bell housing? Let me know how the install went, I will do my best to help.
  5. biker
    3,775
    1,777
    Dec 7, 2014
    I'm not great with figuring out pictures, but is your z bar mounted to the proper holes in the subframe and engine block?
  6. $ Mike 70 Z-28
    $ Mike 70 Z-28 Veteran Member
    1,278
    134
    Nov 7, 2002
    New York, NY
    most likely is your clutch and pressure plate. it happened to me, the same symptoms you have, and it was my clutch it was a centerforce the weights shifted all to one side
  7. big gear head
    big gear head Veteran Member
    6,440
    185
    Jul 30, 2001
    Ky.
    Which bell housing do you have? Are you using one from a Chevy II or a G body?
  8. jbloake
    jbloake Veteran Member
    422
    106
    May 1, 2002
    Atlantic Canada
    From what looks like factory parts I believe the clutch push rod should be on the frame side of the z bar lever , not the block side . There doesn’t seem to be much room . The headers may not be for a manual car .
  9. boltupal
    183
    69
    May 21, 2018
    The transmission, flywheel, clutch disc, pressure plate, bellhousing, release bearing, all linkage , bellcrank and shifter were brand new supplied by SST. There is already holes in the frame so cant be wrong . I've pulled it apart looking for something wrong already. Everything was good. That linkage is suppose to be parallel and perpendicular it neither .
  10. boltupal
    183
    69
    May 21, 2018
    I have changed the headers. Both sets were for a manual trans. If I move the adjustment bar to the opposite side, its misaligned even worse.
