Help with 72 LS-3 alternator bracket
Discussion in 'Original Drivetrain Topic' started by GREGS396, Apr 11, 2020.
  1. GREGS396
    GREGS396 Veteran Member
    2,458
    27
    Oct 16, 1999
    allentown pa
  2. PaulC
    PaulC Member
    53
    Mar 22, 2001
    Is that the original alternator? I thought GM switched to internal regulator in '72? Terminals look like external regulator. My 71 LS-3 setup looks the same as far as the brackets are concerned.
    GREGS396 likes this.
  3. 70L34
    70L34 Veteran Member
    369
    8
    Jan 6, 2004
    British Columbia
    Greg, I notice that you don't have the bracket bolted to the back of the alternator that is supported by the spacer bolt ( see Dave's pic of it). Also, how long is that spacer? Everything on my L34 is the same as Dave's pics, but were things a bit different in 1972?
  4. GREGS396
    2,458
    27
    Oct 16, 1999
    allentown pa
    My bracket on the back is different than Dave's, and that's the issue. I ended up cutting off a little bit to bring it in tighter to the head. It actually ended up being the thickness of the head of the stud where it meets the head. The car was apart when I got it, and I did get a rebuilt alternator years ago.
  5. GREGS396
    2,458
    27
    Oct 16, 1999
    allentown pa
    72 still has the external regulator, 73 was when it changed over.
