Help with heater box nuts and blower motor condenser?
Discussion in 'Body Restoration' started by Adams, Oct 10, 2020.
  1. Adams
    Adams Veteran Member Lifetime Gold Member
    929
    27
    Jul 16, 1999
    From Motown (still in the blood), live in Houston
    71 Z28
    Engine side of firewall.
    Two questions -
    1. currently has a speed nut type of nut. Is this correct or did it use a regular nut on the studs that come through the firewall.
    2. The drawing in the Factory Assembly manual shows that the orange wire to the heater box has a condenser that mounts to the upper lip of the firewall at the cowl for cars with AM/FM. Mine doesn't have one and my 70 SS does not either. Anyone have a car with a condenser spliced into this wire for the heater blower motor?
  2. CaliCamaro75
    CaliCamaro75 Veteran Member
    494
    37
    Sep 6, 2015
    Winchester,CA
    Question 1 I'm pretty sure is a speed nut. At least that's what I pulled off my 75. That's all I could help with not sure about question #2
  3. Twisted_Metal
    29,271
    2,248
    The only condenser I see in my Haynes manual is a tach filter (with radio).
    No condenser spliced into the blower motor for any year that I see.
  4. Adams
    929
    27
    Jul 16, 1999
  5. Twisted_Metal
    29,271
    2,248
    That is odd.
    Did your car come with an AM/FM radio?
    AM only might not have gotten the condenser.
    Judging by the instructions in the assembly manual... It wasn’t a standard part in the electrical harness.
    Maybe it was missed on the assembly line or the part was dropped later in the production year?
  6. Chuck71RS
    1,683
    297
    Nov 24, 2012
    Houston, Texas
    Tim, my 71 RS had AM radio (no tach) but a condenser was in my engine compartment. Only reason I remember the condenser was being unexpected and location found. Don't remember what it was spliced into but it was located close to the joining of four 10ga wires at the radiator core support. It definitely was not spliced into the wire bundle that went to the wire plug on the firewall. By process of elimination this leaves the wire for the blower motor.
