hd_cat
Hi I have a 402BB mild cam and have Holley 750cfm with 72 size main jets the plug keep fouling out will going to a smaller jet fix this or do I need to get a 600cfm if a smaller jet would fix this any recommended size to start with ?
You might consider the following;
- Fuel Pressure 4 - 6psi, most mechanical "replacement" fuel pumps generate more than 8psi, Holley's don't do well with that pressure, it pushed fuel past the needle and seat and runs richer
- Power Valve approximately numbered 1/2 the vacuum level at idle example: 12 inches Vacuum = 5.5 power valve
- Check Primary throttle position, only a small amount of the idle mixture slot should be exposed, beyond that, you're using more fuel than should be used at idle
- Check throttle position Secondaries, use secondary idle screw to slightly open the secondaries, may want to replace the screw with an allen head set-screw
- Install the Power Valve Protector check ball if you have an older carburetor, newer ones have it already
