Holley Choke - Vacuum connection?
Discussion in 'Engine Topic' started by EricsZ28, Aug 23, 2012.
  1. EricsZ28
    EricsZ28 Veteran Member Lifetime Gold Member
    3,486
    Feb 28, 2006
    Here and there...
    Where does the Vacuum line connect on a Holley choke? Should it connect to full-time (manifold) vacuum?
    If so, can I just "tee" off of the full-time vacuum line running to my mechanical advance on the distributor?
    Thanks!
    This choke:
  2. Damon
    Damon Veteran Member
    12,939
    23
    Nov 16, 2000
    Philly area
    Yes IF..... your carb and/or choke does not have provisions for an internal vacuum connection (between the back of the choke housing and the carb main body). If the carb came as an electric choke from the factory the passage is usually internal. If it's an add-on it's usually external. I'm guessing yours is an add-on.
    The vacuum source works the internal "choke break" vacuum piston that pops the choke open slightly upon initial cold start-up.
  3. EricsZ28
    3,486
    Feb 28, 2006
    Here and there...
    Thanks, Damon. Yes, this used to be a manual-choke carb. The electric choke is an afterthought. The internal vacuum source is plugged.
