Holley Primary Metering Plate 5882 4716 Application?
Discussion in 'Original Drivetrain Topic' started by bkmont, Jun 3, 2021.
  1. bkmont
    bkmont Veteran Member
    1,239
    125
    Nov 14, 2010
    Pensacola, Florida
    What application for this primary plate?
    Thanks,
    Bryan
  2. COPO
    20,875
    2,465
    The 5882 was used on 1969 HOLLEY LIST 4295 CAMARO CROSS RAM 2X4.
    Holley 4716?
  3. G72Zed
    G72Zed Veteran Member
    2,907
    1,413
    Sep 8, 2015
    to ass to COPO great info, this Holley primary metering block could be worth $$ to a collector or owner of an OEM cross ram setup.
    Kill bleed, Emulsion & IFR location and PVCR's looks to be along the regular Holley specs, just like a primary 1850 or 4776/7 metering block.
  4. bkmont
    1,239
    125
    Nov 14, 2010
    Pensacola, Florida
    Thanks guys for the info. This block was on a list 4555 along with the 6333 4555. So, two primaries on the carb. Why would someone do that? Any benefits?
  5. COPO
    20,875
    2,465
    Most likely scraping together what they had without spending any money to make the car run is my guess.
  6. G72Zed
    2,907
    1,413
    Sep 8, 2015
    They would do that to have a functional rear power valve & PVCR's, and most of all, 4 corner idle capability if the mod's are done to the base plate, so, a few benefits, win-win actually.
  7. COPO
    20,875
    2,465
    Non idle mixture screw rear metering blocks had power valves on Holley vac sec carbs. But if you went with a 3310-2 the secondaries just had a plate to cut Holley costs down. I’d rather adjust a 2 idle mix screws metering block on the prim instead of making a 4 corner adjustment by using a prim metering block on the rear. If I’m polluting a bit, who cares.
  8. G72Zed
    2,907
    1,413
    Sep 8, 2015
    Yup, agree with you on that COPO, but setup right, one does not pollute more than the other, the 4 corner just allows a larger window in more serious engine applications, but the 2 corner can take you far.
  9. bkmont
    1,239
    125
    Nov 14, 2010
    Pensacola, Florida
    I'll just keep looking for a correct secondary block for the 4555.
  10. COPO
    20,875
    2,465
    You want a 4519.
    bkmont likes this.
