Aussie78Z28
- Nov 17, 2017
- 48
Awesome mate - thanks for taking the time to step through the process. I really appreciate itI actually just about finished up installing and plumbing an Aeromotive Gen II Stealth tank. Went with the 200lph pump. My old tank was dented, crusty, and would've needed to be drilled or something to get a return line into it. If it had been in mint shape I probably would've gone with that Holley drop in unit and cleaned the old tank, but the Aeromotive tank is $500 and it's painted, assembled, baffled, and ready to run out of the box. The in-tank pump on that thing is dead silent too, all I can hear is the relay clicking on and off out by the battery. Curious if it'll be audible once it's loaded down with 58 PSI though, currently regulated to 6 PSI to run the soon to be retired qjet. Ran 10 gauge power and ground wire through the inside of the car, following the rest of the wiring that runs through the trunk and up to the front. Aeromotive insists on 10 gauge (12 minimum) to minimize voltage drop, not because the pump draws an unusual amount of current or anything.
I have a Firebird so my original 3/8 fuel line runs up the left side, and there are 1/4 and 5/16 vapor return and EVAP lines on the right side. I actually put a charcoal canister back in so I'm using the 5/16 line for that. The 1/4 line was unused so I trimmed and rebent some of it to make a template to use for bending the 3/8 feed and return lines to run along that side. I mounted the 10 micron filter below the right door, which allowed me to make the feed line 2 pieces to ease the bending and installation. I also split the return line in the same area and have a -6 AN union there to join the front and rear sections. I went with Earl's Vapor Guard hose and hose ends because I just don't see the need for fancy braided stuff for how I use this car.
I spent a long time hemming and hawing about how to do the fuel system on this thing. Even made a spreadsheet of the different options and prices and narrowed it down to the combo that made sense. Then spent even more time doing image searches and thinking about how to route everything because I didn't want to accidentally end up with something annoying to service or routed poorly/in the way of something else. At some point you just gotta decide to start doing it and hope you aren't short some critical part. I did it by myself on a driveway with the rear end up on some ramps and that seemed like plenty of room. I wouldn't say any of it was hard to do, just time consuming and sometimes tedious depending on how fancy you get.
Next step will be to install a Holley Sniper. I was actually going to do just the fuel system and stop there because I want to swap in a Gen III 5.3 or 6.0 at some point, but a new opened but unused Holley Sniper popped up for a low enough price that I couldn't ignore it, so it seems the BBC will be hanging around for a while longer if it doesn't grenade randomly.
My fuel system's not exactly pretty, but I'm happy with how it turned out. I'll try to take a few pictures tomorrow when I go fiddle with it more -- still need to empty and remove the old feed line before really driving it.
