Hooker Competition Headers any good?
Discussion in 'High Performance Modifications' started by reinhardt79, Feb 19, 2016.
  1. reinhardt79
    reinhardt79 Veteran Member
    858
    May 12, 2002
    VA BCH, VA
    I found a set on Craigslist for $200. I'm looking to build a 454 for my 79. I'd be happy to tuck these away until I get a motor built, if they are worth having. Is $200 a good price? Thanks guys.
    https://norfolk.craigslist.org/pts/5407510877.html
  2. Rich Schmidt
    Rich Schmidt Veteran Member
    4,284
    40
    Mar 27, 2010
    Denville NJ
    They are great headers,but you can buy them brand new for less than that.
  3. Rustbucket350
    Rustbucket350 Veteran Member
    885
    40
    Sep 4, 2013
    Oviedo, Florida
    I had the small block ones and I liked them. They fit well and looked good when they were new. The bottoms rusted out after a couple years but I guess that's the case with any of the regular black headers. I have a set of the cheap Summit ones to replace them and the fit is a little disappointing compared to the Hookers.
  4. CorkyE
    10,919
    696
    Agree with Rich, that's about the price of new from Summit, Jeg's, etc. I'm very leery of buying used headers that someone has spray painted anyway.
  5. middleagecrisis
    middleagecrisis Veteran Member
    967
    Oct 22, 2007
    I've always had good luck by removing the cheap paint off of the discount headers and applying a quality high-temp header paint. Heat cycle the headers a few time and the paint will stay on a lot longer than the factory applied paint.
  6. rocket dawg
    rocket dawg Veteran Member
    382
    46
    May 5, 2015
    Grand Rapids Mi
    Maybe these are Hooker "Super" Competition headers?
  7. sandiego74
    sandiego74 Veteran Member Lifetime Gold Member
    1,141
    71
    Feb 23, 2009
    San Diego, CA
    Just to add to what the others said, they are unequal length, so expect that. I'm not sure if other brand headers are this way, but my Hooker Competition's are.
  8. MagicRatt
    MagicRatt Veteran Member
    1,129
    17
    Aug 24, 2004
    Southampton, Pa.
    Careful on the fit....I tried a set of 2 inch comps on my 70 396 4speed car and they didn't clear the reverse lock out linkage. I went back to the super comps and they were designed to clear the lock out linkage. Huge difference in cost. You can re-route the tube on the comps if you choose to. I went back to the SC's....the first set lasted almost 25 years......
    Rich
  9. vfitom2aol.com
    vfitom2aol.com Veteran Member
    3,698
    Mar 2, 2000
    NE PA
    I've used Hookers a lot and liked them.
  10. Maine1
    Maine1 Veteran Member
    165
    Nov 19, 2014
    Franklin County, Maine
    Before you get to far into final fitment be sure to check plug and plug wire clearance.
