Hooker / Holley's new 2nd gen LS set-up
Discussion in 'High Tech Retrofits' started by mikes70, Nov 20, 2013.
  1. ks71z28
    ks71z28 Veteran Member NastyZ28 Sponsor NastyZ28 Sponsor Lifetime Gold Member
    2,150
    52
    Oct 10, 2004
    chico, ca, usa
    Mike call us on Monday
    Keith
    Custom Works
    530 864-5846
  2. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    Does this indicate the 70-74 kit is available?
  3. ks71z28
    2,150
    52
    Oct 10, 2004
    chico, ca, usa
    We have installed all of the Holley/Hooker stuff many times and we have a package that gives you the best fit and ground clearance for 70-74 and 75-81 F-bodies. I don't recommend the kit as a whole for the 70-74. We are an authorized Hooker/Holley dealer and installation center as well
  4. Protour-Camaro
    2,111
    Feb 16, 2012
    California
    Keith, Im also looking for a good set-up, but I have the DSE frame.
  5. ks71z28
    2,150
    52
    Oct 10, 2004
    chico, ca, usa
    I'm pretty sure you are stuck buying ALL their stuff, mounts, headers, etc
  6. mikes70
    mikes70 Veteran Member
    202
    Apr 24, 2008
    livermore, ca
    What he said.
    My frame rail is 4 1/4 from the ground, low but not slammed. The Hookers sit at 1 3/4". I must do the exhaust for the THIRD time.
  7. turbodarryl
    turbodarryl Veteran Member
    356
    Dec 22, 2012
    Walker, La. Hometown NOLA
    I have a 73 and I can say this from trial an error, im using the kooker mounts and trans crossmember and the LATE 2nd Gen headers, if your looking for max ground clearance then you can't go wrong with that setup, I tried both the early an late Hooker and the late headers from Hooker fit the early Gen the best.
  8. ks71z28
    2,150
    52
    Oct 10, 2004
    chico, ca, usa
    Mike thats how low they were with the early headers, where does it sit now? should be about 3/4" lower than the frame
  9. mikes70
    202
    Apr 24, 2008
    livermore, ca
    The later 2nd gen ones netted me an inch, Hooker sent me painted ones, so while they fit better, i have to coat them or order another set. I understand there is a coating source on the peninsula (here in the Bay Area) so i might go that route and jjust do the passenger side.
    For maximum ground clearance, middy's? what are your thoughts Keith?
  10. lumpy12
    lumpy12 Veteran Member Lifetime Gold Member
    727
    15
    Sep 16, 2012
    NorCal
    Sanderson Headers in South San Francisco is the place that coated my headers and I'm very happy with them :)
    http://www.sandersonheaders.com/Sanderson-Thermal-Ceramic-Coating.html
    tim
