Hooker / Holley's new 2nd gen LS set-up
Discussion in 'High Tech Retrofits' started by mikes70, Nov 20, 2013.
  1. saved1992
    saved1992 Veteran Member
    129
    Mar 21, 2013
    bennington, ne
    Thanks !!
  2. csjrishere
    csjrishere Veteran Member
    127
    Dec 7, 2010
    Pittsburgh, PA
    Awesome...I will be trying to order some.
  3. toddoky
    toddoky Veteran Member
    227
    Mar 5, 2013
    Bowling Green, KY
    The Hooker 1970-74 F-body LS engine mounting kit
    The Hooker 1970-74 F-body LS engine mounting kit (12512HKR) is now available on the Holley website...now waiting on a reply for the long-tube status.
  4. 72-Z/28
    72-Z/28 Member
    77
    Dec 28, 2012
    Birmingham, Alabama
    I can vouch for the hooker/ holley set up. I am running the ls1/4160e motor mounts and trans mount. I installed them a few weeks ago,they line up perfectly and put the pinion angle at the correct spot. I am waiting for the Longtubes to be released so I can grab those as well. Any eta on when these are going to be released?
  5. 1934chevycoupe
    1934chevycoupe Veteran Member
    270
    Mar 12, 2013
    Harleysville, Pa
    was looking at the headers on hooker's website. w/ no flange, how do they connect to the tailpipes? also, was looking at holleys accessory drive system on holley's site. looks nice, just like a stock setup, but couldn't find a suggested price anywhere on just the brackets or the complete sytem. looked on summit and they only showed the spacer kit you'll need.
  6. stroked383
    stroked383 Veteran Member Lifetime Gold Member
    764
    Jul 18, 2011
    Saugerties, NY
    If you take the part number from Holley and plug it into Summit it will give you the price. like 20-143 is $749.95
  7. toddoky
    227
    Mar 5, 2013
    Bowling Green, KY
    For reasons of maximized ground clearance, a Torca sleeve coupler is used to attach the headers to the Hooker exhaust system. It's the same clamp that is used by Ford on the late model Mustang exhaust.
  8. mikes70
    mikes70 Veteran Member
    202
    Apr 24, 2008
    livermore, ca
    Todd, is this the same adapter you mentioned to me at SEMA regarding the 3" header to the 2.5" Dynatech exhaust? BTW, yours you said is like 20.5" on CL at the lower header exhaust and i measured 22.5" +/- on my Dynatech set-up. I dont want to pitch their exhaust so i guess i will "bend" it too fit.
    My Dynatech headers, with Transadapt engine mounts, Hotchkis spring, the t-56 rubbing the top of the tunnel (well 1/4" of clearance) place the collector at 2.375 from the finished floor in my garage, way too low imo.
    I'm gonna order your ceramic longtubes as soon as there ready (if the s/s ones are ready first, i may order those). Keith at Custom Works is doin the front end suspension/steering soon...
  9. mikes70
    202
    Apr 24, 2008
    livermore, ca
    BTW, the Holley webpage is down
  10. toddoky
    227
    Mar 5, 2013
    Bowling Green, KY
    Hey Mike, I was down in our manufacturing facility last week delivering the welding fixtures for our 1st-gen headers and say them bending the 1970-74 long tubes you've been waiting for.
    When I asked them when they expected to be finished with them, they said just before Christmas for all the mild steel versions (painted and ceramic coated). I wanted to let you know all this before I leave for the PRI show this afternoon and forgot to tell you. Hopefully this helps you in your planning.
    By the way, the 1970-70 engine mounting kit is now available, so you can pick up one of those and a the correct Hooker crossmember to get your engine and trans mounted in preparation for installing the headers if you want to.
