Horn Lead Wire
Discussion in 'Electrical Systems' started by Bandit723, Sep 2, 2019.
  1. Bandit723
    Bandit723 Veteran Member
    3,265
    485
    Oct 1, 2016
    Waupaca WI
    Does anyone know what horn lead wire is used on the Camaro steering column or better yet a part number. It is a 79 non tilt column. EDIT: trying to make this work with a Grant Steering wheel.
  2. Bandit723
    3,265
    485
    Oct 1, 2016
    Waupaca WI
    Well was hoping for a response. But {crickets}
  3. Twisted_Metal
    27,699
    1,308
    According to my Haynes manual... It should be a black, 20 ga. wire.
    (Circuit # 28 at the column connection.)
    The connection at the horn button is a ground.
    It completes a circuit to trigger the horn relay.
    I was able to make it work with a Grant wheel but it's been several years since I've had the steering wheel off.
    I know I was able to fit a window crank emblem into the center of the wheel. (IIRC, I had to dremel a little notch in the edge to make it fit.)
    I used a piece of spiral notebook wire to fabricate a spring under the button.
  4. Bandit723
    3,265
    485
    Oct 1, 2016
    Waupaca WI
    Thanks Terry the 20 ga. wire hopefully points me in the right direction as to what part to get to try and get this to work. I know some of the older columns used a pin that stuck up rather than the wire with a brass end going into the column.
  5. Twisted_Metal
    27,699
    1,308
    Did your horn work before you pulled the wheel?
    There's supposed to be a little contact piece inside the spring and the notch on the insulator (green piece) is used to lock it in place.
  6. Bandit723
    3,265
    485
    Oct 1, 2016
    Waupaca WI
    No. it's the contact piece that i am missing so i am not sure still as to what works. saw the Dorman replacement "long wire" but is not listed a a replacement for the Camaro and the GoodMark but is a pin rather than a wire.
  7. Twisted_Metal
    27,699
    1,308
    I can see the spring.... I think you're missing the two pieces on the left side of this pic.
    Rene Melten likes this.
  8. Bandit723
    3,265
    485
    Oct 1, 2016
    Waupaca WI
    ok makes sense. yes the two pieces on the left are missing or should i say the collar looks right. I would assume i could solder the ground wire to the contact pin the attach it to the retainer ring under the horn cap?
  9. Twisted_Metal
    27,699
    1,308
    Is the wiring missing through the spring?
    It should have a little brass button on the end of it for the spring to make contact. (I think.)
    Here's a video of someone who fashioned a circuit for a Grant wheel.
    The first part of the video might help. (I think he bypassed the horn relay in the second part.)
  10. Bandit723
    3,265
    485
    Oct 1, 2016
    Waupaca WI
    Looks more like i need to connect to the retainer. The black collar looks too long sure it could be cut down to size.
