Hotchkis rear leaf springs( kit )2408C
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 1973camaro406, Jun 4, 2012.
  1. 1973camaro406
    1973camaro406 Veteran Member
    238
    Sep 8, 2006
    Just got my kit in today.2408C
    Ok here's the deal, I was gonna get summit brand leafs for about 220
    I saw the hotchkis and it was 429.95 so I was convinced summit would be better.If you look close it says (with install kit for hotchkis).You get front and rear bushings, shackles with blots and locking nuts.New heavy duty u bolts and caps. new poly pads upper and lower. Also get those funky u shapes clipbolts that hold the front of leaf to body and bolts. All and all I think its about the same $$ if you buy all the parts separate that come with this kit.GREAT JOB HOTCHKIS!!!!!!!
  2. 1973camaro406
    238
    Sep 8, 2006
    Anyone know why manufacturers use rubber bushings up front with poly in back?
  3. Vsolo
    Vsolo Veteran Member Lifetime Gold Member
    828
    15
    Sep 20, 2009
    So Central PA
    That is one nice thing i liked when I got my Hotchkis, you get all the parts and don't have to run around finding stuff.
  4. Vsolo
    828
    15
    Sep 20, 2009
    So Central PA
    ??? Who, what part ?
  5. cars4life
    cars4life Veteran Member
    646
    Jan 11, 2010
    Poughkeepsie N.Y.
    I just got my hotchkis front and rear springs delivered today and was surprised with the amount of hardware also. I will not be useing the rubber bushings up front, I will use solid aluminum bushings with caltrak bars.
  6. warped
    3,212
    Oct 20, 2003
    Sitting in my command bunker waiting for the zombi
    I can't say why they do this, but I put poly in the rear shackle bushings and will be taking them out soon. The poly bushings bind up and then snap loose on acceleration and deceleration. I don't think it is dangerous, but the feel is noticeable and very annoying. I have delrin bushings from Custom Works to install in the rear and the front has the spher-o-bushing from ptfb.
  7. tferg51
    tferg51 Veteran Member
    181
    May 10, 2011
    New Waverly, Texas
    Look at the part numbers on the bushings for the body and shackles. One supplier uses the same for both and one uses one for the frame and a different one for the spring. I installed mine before I noticed it in the instructions and then had to take one back out only to find that I had the kit that used the same bushing in the frame and spring.
