how big of a slick fits in a stock wheel-well??
Discussion in 'Competition Camaros' started by BlackDog82, Jul 9, 2013.
  1. BlackDog82
    BlackDog82 Veteran Member
    557
    Jul 29, 2003
    State of Confusion
    am thinking of having my '79 back-halved, and although this constitutes 'cutting-up' the car, I'd rather not s-t-r-e-t-c-h the wheel-well opening,
    leaving it as it came, which will probably limit the size (height) of slick that can be used
    any first-hand knowledge is greatly appreciated, and pictures are even better!!!
  2. mrdragster1970
    7,821
    507
    Apr 12, 2007
    Stock wheel well on my 70 1/2 fits a Hoosier 29.5 x 10.5W, it's real tight, but it's a track only car, no biggie.
  3. BlackDog82
    557
    Jul 29, 2003
    State of Confusion
    is the problem the leading & trailing edges of the wheel-well, or is your problem clearance inside?
    I'm leaning towards a narrowed frame-rails & rear-end, wheel tubs, ladder-bars, etc., so I don't think a problem 'inboard' would be the limiting factor...
    ... or am I wrong (like usual)?​
  4. Blown Camaro
    Blown Camaro American by birth, drag racer by choice
    1,199
    140
    Dec 13, 2009
    Deltona, FL
    You will be able to fit a 315 radial if you tub it.
  5. mrdragster1970
    7,821
    507
    Apr 12, 2007
    I was limited by the front, that is closer then the rear of the opening.
    Now if you do start cutting, you will fit a 30" & maybe more without touching the quarter.
    I ran a 30 x 9 for many years, so if you go inward, your only limiting issue is the shape of the quarter.
    I would have to look, I don't know how wide they go on a 30" tall slick??
    If it was me and I didn't want to touch the quarter, I would just do a mini tub.
    A monster tire will have to sit way inside to fit, and I hate that look.
    Good luck.
  6. mrdragster1970
    7,821
    507
    Apr 12, 2007
    This is one of my cars. I'll try and explain what I mean.
    Look above the quarter, they had to add a notch, to make room for the 34.5 tall tire.
    It still sits in from the quarter more then I would like, but picture it without the notch.
    The damn tires would have to touch & they would be a foot from the quarter??
    So unless you have something like a truck, or a straight quarter, a huge tire will look silly without stretching the opening??
    Oh and this has been stretched like a foot, and the tire still has to sit that far in.
    [​IMG]Uploaded with ImageShack.com
  7. BlackDog82
    557
    Jul 29, 2003
    State of Confusion
    Me, too, and it is hardly worth doing, just to fit a 30" x 12" slick , assuming that is the widest available at that height
    (I've already had 29" x 11" in the existing opening):
    I was hoping to go 32" x 14" minimum, but that appears to be a fantasy without massaging the 1/4-panels
    I was already planning to replace the 35 year-old original paint, so I guess we'll be stretching the wheel-wells,
    but I'd still appreciate seeing pictures, if anybody has some​
  8. BlackDog82
    557
    Jul 29, 2003
    State of Confusion
    this is a buddy's Monte Carlo, with 33" x 15" sitting inside stock opening
    I know the slab-sides make it easier, but I was hoping for something like this​
  9. mrdragster1970
    7,821
    507
    Apr 12, 2007
    A Monte makes it easier, then the slope we have to deal with.
    Have you looked at the 31 x 10.5 W, I have several friends that run in the 7's with that tire.
    You will have a nice combo and it will take less cutting & messaging??
    Maybe post or ask around if anyone has that tire on a 12" wheel and take some real world dimensions??
  10. HOLESHOT
    HOLESHOT Veteran Member
    1,043
    Feb 19, 2009
    mesa,az
    ive had 30-10.5 on my car and 29-12.50s all stock suspension and wheel tubs
    no rubs
