how big of a slick fits in a stock wheel-well??
Discussion in 'Competition Camaros' started by BlackDog82, Jul 9, 2013.
  1. jplace
    jplace New Member
    13
    Jul 8, 2010
    Pottstown, Pa
    I have an 81 Camaro tubbed stock wheel well. I have a Good Year 31x14x15. It fit but when I did a burn out the left side rubbed on the front of the wheel well putting a gouge in the slick. I ended up cutting the wheel well front and rear to get the slicks to fit. Didn't want to do it but wanted to go racing. The car had a Hoosier Quick time 31x18x15 on it when I bought and it didn't rub. If that's the type of tire you want it should fit.
  2. Rich Schmidt
    Rich Schmidt Veteran Member
    4,285
    40
    Mar 27, 2010
    Denville NJ
    29.5 is tight and will probably scuff the opening. On my Firebird,I toop a hammer and tapped the wheel opening forward,then used a trans am wheel spoiler to cover up the work. It makes the fact that the slick sticks so far out past the rocker look more finished.
    BTW,A the front of a Firebird wheel opening ends at the same point as a Camaro because the rockers are the same.
  3. BlackDog82
    BlackDog82 Veteran Member
    557
    Jul 29, 2003
    State of Confusion
    31" x 14" would probably work for my application, a (very) mild SBC on alcohol:
    any pictures?​
    funny you should mention the rear wheel flares
    when the 1980 Z28 debuted, the first to have those (specific to the Camaro), I bought a pair, for 'someday down the road',
    and your post made me go looking for them:
    the car's been stored for most of the last 20 years, and when I opened the trunk, there they were, sitting on top of the OEM steel wheels,
    having the original Blue & White GM part-number stickers still attached​
  4. strstk71
    strstk71 Veteran Member
    536
    Aug 12, 2005
    Surrey BC Canada
  5. Infidel Camaro
    Infidel Camaro New Member
    12
    May 15, 2012
    Slinger, Wisc.
    I ran P295-50r-15s on my 79' ..looked great, but was close to the outer fender well..ran 5-leaf springs in the back for better height...Sarge
  6. Skip Fix
    Skip Fix Veteran Member
    2,217
    25
    Mar 21, 2007
    Katy,Texas
    I borrowed a set of 29.5x10s years ago on Vette Rally wheels a friend was running OK on his Camaro. They grew enough on the big end to wipe the paint off the rear of the fender lip on my 78 TA.
    If there is a radial slick in the sixe you are looking at they grow very little and you can run close to the fender edges.
  7. fuzzy dice
    fuzzy dice Veteran Member
    651
    Apr 16, 2008
    Deltona, Fl.
    I currently run 28x10.5x15's...I have run 30x9x15 DR slicks as well...we had to punch in the front of the wheel wells where the rear seat belts used to fasten to the body...my new 465 BBC may present some launch issues...if it does, I am going to look into Smith Racecraft traction bars...much more adjustable than the Caltrac system and $334.00 versus $4 grand to tub it...
    Dead hook is dead hook so we will see shortly what will happen...I am told my new glide will soften the hit enough...this is mine and the slicks have 1/4 inch clearance from the leaf springs...
    Taken last Saturday...mine is hooking just fine with the small tires and glide...still tuning but getting there...
  8. ProStreet383
    ProStreet383 Veteran Member
    2,106
    9
    May 23, 2007
    MD
    Mine is mini tubbed and I fit a 325 just fine.
