How can I save a door sticker?
Discussion in 'Original Drivetrain Topic' started by pulpcowboy, Jan 4, 2010.
  1. pulpcowboy
    pulpcowboy Guest
    Have to replace a driver's side door and has the codes to the car on the sticker. Anyway to save it or just forget it?
  2. Gary S
    23,796
    1,450
    You will probably damage it trying to get it off, but if you can scrape it off so it is basically intact, you can send it to ECS Automotive and they can reproduce it for you. They are a little pricy, but with the VIN on it, duplicating them without the original might some day have issues. Then put on the new one and keep the remains of your original one.
    http://www.ecsautomotive.com/
  3. pulpcowboy
    pulpcowboy Guest
    Wow, what a great site, never knew of them. Since it has to come off anyway will send them the old one.
  4. al8apex
    al8apex Veteran Member
    3,918
    Mar 11, 2005
    scottsdale, az
    I saved my original by laminating a thin layer of 3M clear plastic film (can't remember the exact product) over the tag and then removing it whole. Worked well except I forgot to take a picture of how/where/what angle it was originally on the door edge ...
  5. 70 LT1
    70 LT1 Member
    92
    Jan 3, 2002
    Dallas, TX
    I have heard that using a heat gun on the backside will sometimes remove the sticker. Have not tried this yet though.
  6. SG71SS
    SG71SS Veteran Member
    1,281
    8
    Dec 16, 2004
    Los Angeles, California
    The sticker on my Citrus Green 71ss is very brittle and already missing a corner. So I'll get the reproduction version but keep the original sticker:
  7. kevin chamier
    kevin chamier Veteran Member Lifetime Gold Member
    281
    Oct 20, 2006
    heat gun might be walking the fine line of good or real bad results. the sticker might bubble up before the adhesive goes. try the heat gun on a old inspection sticker or something similar . how hard is it to get a fresh razor blade under it? then try and get some detergent to work in underneath:bowtie:
  8. al8apex
    3,918
    Mar 11, 2005
    scottsdale, az
    hmmm, the point is being missed somehow
    as I stated earlier, apply a thin laminate over the sticker so it does not fall apart ... then do your removal tricks
  9. 70 SS/L78
    2,900
    139
    May 5, 2005
    Rockford, MN
    I used a straight edge razor blade to remove mine, took some paint off with it but it came off completely intact.....thou, it was 20 years ago!!
    Not sure if i'll reuse it but I was able to reproduce my own by scanning it and playing with the color shade in Photoshop to reproduce an exact duplicate.
  10. RICARDO1969
    RICARDO1969 Veteran Member Lifetime Gold Member
    2,086
    Oct 14, 2007
    Waukesha WI
    use a cut off wheel lol!
