How do you clean up 40 YEAR Old Control Arms?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by ratpatrol71z28, Dec 6, 2012.
  1. ratpatrol71z28
    ratpatrol71z28 Veteran Member
    1,577
    Mar 29, 2012
    Mantweeka, California
    :) What can I do to get all those years worth of gunk, debris, and grease off my LCA's I am going to put in new bushings and ball joints and I's like to paint them nicely.
    What is a good cleaner to spray on? Engine Brite I have already sprayed on the went to try to power blast them but not much came off.....
    How should I get out the old bushings and joints?
  2. Marks71BB
    11,834
    Aug 25, 2002
    Gods country in the beautiful Sierra Mountains of
    a heavy duty scraper and lot of work. soak em for a couple days in soapy water will help. If its undercoating a torch will help soften it up.
    There are you tube videos of how to remove and install bushings and ball joints.
    here's one...on a second gen f-body even!!
    [youtube]iG1hQlw6xMk[/youtube]
  3. Kamikaze
    5,040
    Aug 4, 2005
    So. Lake Tahoe CA. USA
    Oven cleaner will help remove the grease and general grunge.
    It will soften undercoating only slightly but enough to scrape off to clean with solvent
  4. hhott71
    14,377
    9
    Mar 30, 2001
    Joplin Mo. 64801
    Once they are off hot tank them at the friendly engine builders shop. An overnite dunk willl do the job. pre BJ and bushing installation.
  5. 1971CamaroGuy
    3,838
    202
    Oct 31, 2004
    Here are the steps I do my grimy parts before paint
    1. Oven Cleaner or Engine Degreaser in the can, soaking for a few hours or so
    2. Power wash the part
    3. If there is any tar or heavy grime left I try to scrape it first
    4. If it's too thick, I hit it with a wire wheel on a hand held grinder..it's messy but will break the tar/grime down
    6. Power wash again, let dry
    7. Then sandblast the part to bare metal, this will remove paint and light grime or tar still left
    It may or may not be correct, but works for me :cool:
  6. Hoot
    Hoot Veteran Member
    1,475
    Jul 12, 2008
    Greenville MS
    How I do it.
    Oven cleaner
    power wash
    Then i use electrolysis to clean all the rust off. Basically I dunk them in a water/washing soda bath with a battery charger hooked to them over night.
    Power wash/light brush any left over scale.
    Dry
    Paint
    I remove old bushing/ball joints with an air hammer/chisel. 10-15 seconds a piece and they are out. Old mechanic friend showed me this one.
  7. nonstopgo68
    nonstopgo68 Veteran Member
    875
    Apr 19, 2011
    Mobile, Alabama
    I just used an electric drill and a zizz wheel( or wire brush wheel)
    check out my link to see how mine turned out.
    You dont have to get it down to bare metal just get all the dirt and grime off
  8. RICARDO1969
    RICARDO1969 Veteran Member Lifetime Gold Member
    2,086
    Oct 14, 2007
    Waukesha WI
    Throw them in the scrap pile and buy tubulars lol
  9. fnoblitt
    fnoblitt Veteran Member
    429
    Jul 4, 2009
    riverside calif.
    [​IMG] this will make it a quick job
  10. ratpatrol71z28
    1,577
    Mar 29, 2012
    I have Heidts tubulars but they are 1 inch narrowed sadly..... I'd like some matching LCA that are Global West, anyone interested haha.... thanks alot guys!!!
