how many times can a crank get turned
Discussion in 'High Performance Modifications' started by ripcurl329, Nov 21, 2010.
  1. ripcurl329
    ripcurl329 Veteran Member
    320
    May 14, 2008
    Fredericksburg, Va
    How many times can a crank get turned?
    I have an 1182 steel crank and it has been turned already...
    but when is it too much and it starts to take away from performance?
  2. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    When you can't get the correct size replacement bearing
  3. Rich Schmidt
    Rich Schmidt Veteran Member
    4,285
    40
    Mar 27, 2010
    Denville NJ
    Guys cut cranks WAY down. Some guys will turn the crank you have all the way down to small journal rod size to reduce bearing speed in high rpm engines,or even offset grind them down to the small journal size to increase stroke. My personal opnion is to have the journals hardened after any time you have the crank turned.
  4. z28rod
    z28rod Veteran Member
    4,472
    Apr 30, 2009
    hopewell junction,ny
    good advise on high hp engines..
  5. Rick WI
    10,400
    Jul 9, 2001
    Madison, WI
    How do you re-harden a forged crank? How does the machining change the forge? I see a lot of cranks go from the grinding machine to the engine with no issues at all. Nitride treated, different story.
  6. NYH1
    NYH1 Veteran Member
    1,604
    12
    Feb 27, 2010
    Central New Yorkistan
    What is Nitride treated??
  7. Cardinal
    8,329
    58
    Jun 22, 2003
    Endicott, NY
    As said, usually can be turned till you can't find bearings to fit it. A "standard" undersized maximim would be .030" on a 350 large journal crank unless you consider that you can also grind it to a small journal Chevy crank diameter which would also include .030" undersized bearing for that too.
    They also use a cryogenic freezing process to harden them. It creats less stress on the metal yet hardens it.
  8. ripcurl329
    320
    May 14, 2008
    Fredericksburg, Va
    Thanks for all the info.
    I know my crank had already been turned to .030". The machinist said that he would check to see if it is straight and that he could turn it... but at the same time he also stated when i asked about how far you could turned it down " you wont drive it a million miles a day"... so that made me think it was starting to take away from performance and durability.
  9. Cardinal
    8,329
    58
    Jun 22, 2003
    Endicott, NY
    IF it's already turned .030", seriously think of what the concequences are if the crank fails (broken block, bent rods, etc.). IMHO, cut to the chase and buy a new standard forged crank.
  10. jakeshoe
    8,908
    53
    Dec 8, 2000
    Republic of Texas
    You can get .050 under bearings for a SBC. It doesn't weaken the crank, if properly machined it will actually be stronger.
