Hey guys, I have a few parts I'm going to sell here very soon and needed help figuring out what they are worth!! Please chime in with any ideas, Thanks! 1. 330545 Cylinder Heads off my 1973 L-82 engine. The dates match up on both heads (Feb. of 73'), they are the thick casting style with 2.02/1.60 valves. They have screw in studs & guide plates, springs, rocker arms,etc. - everything factory installed, they are complete heads that have never been touched and only have 64,000 miles on them. 2. Distributor 1112347 with correct date. Also comes with rotor and cap to it. 3. Intake - "Edelbrock" 'Speedmaster'. 4. Carburetor is Holley 750cfm double pumper with electric choke, it either came with the car in 73' or was purchased within a few years of 73' Like I said, any help would be much appreciated. Thanks guys, Jay
If your car has the original motor they are worth Way more to you keeping them. Those are low compression 76 cc heads they would only have value to a 73 vette or z owner who need that build date. FYI ask the WIW questions in the Camaro engine or 70-73 Camaro question sections. The swap meet section must have a price per forum rules.
Agreed. As a 73Z owner, the only reason to buy these heads are if you're doing a stock resto. Otherwise, there are better alternatives out there. Although the ones you have are low mileage, they may need a rebuild. I think $750 would be about right to someone that needs them. The correct distributor is #1112148, so the one you have is not correct for a 73Z. Also, the intake should be a cast iron GM and the carb a Q-jet. https://nastyz28.com/camaro/z28l82.html
Hey fellas, thanks so much for your replies, they were incredibly helpful! Also, thx for the tip on where to put it in the future. Thx, Jay
