How much does a rearend weight?
Discussion in 'Camaro Questions' started by badazz81z28, Sep 12, 2005.
  1. badazz81z28
    19,206
    1,086
    Alabama
    I think I can get way with shipping a rear fedex ground if I pull the axles ship them seperatly. That is if the rear weight is less than 150lbs W/O axles. Anyone know its weight? Thanks!
  2. Jet
    Jet Veteran Member Lifetime Gold Member
    3,613
    Sep 23, 2004
    Look over your shoulder
    I can lug a differential around without axles & with the gears still installed, so I know it can't weigh more than 150#. Just did this a few weeks ago. I can still lug it around WITH the axles and backing plates installed, but it makes it a hell of a lot harder.
  3. Daniel
    Daniel Veteran Member
    3,758
    Sep 6, 2000
    FL
  4. GREGS396
    GREGS396 Veteran Member
    2,446
    25
    Oct 16, 1999
    allentown pa
    The 250 range is pretty close. I shipped one a while ago by FedEx Heavyweight. I left the axles in, and put all of the Disc Brake components in a box. I then had everthing banded and wrapped onto a Skid.
    Using FedEx Ground will be cheaper, but I don't know what their weight limits are. Check their Website to see.....
  5. badazz81z28
    19,206
    1,086
    Alabama
    How much did it cost you?? Fedex ground has a 150lb limit for a bussiness delivery. When you say skid your meaning wooden pallet?
    Thanks
  6. GREGS396
    2,446
    25
    Oct 16, 1999
    allentown pa
    Yes, a wooden pallet is what I used. The cost is going to depend on where you are shipping it to. If you go onto their site and go to shiipng/get rates you can get a close estimate. I sent mine from PA to MO by 3-day freight. I think it was around $160, but my place of work gets a volume shipping discount with their account.
  7. Kamikaze
    5,038
    Aug 4, 2005
    So. Lake Tahoe CA. USA
    The rear end even without axles will be considered "oversize" and will have a surcharge on top of the weight charges.
    Be careful when sending things via Fed Ex Ground.
  8. badazz81z28
    19,206
    1,086
    Alabama
    Who has resonable freight rates??? Fedex and UPS both around $400!!
  9. midnight motor
    midnight motor Veteran Member
    565
    Mar 24, 2003
    sacramento,ca,usa
    I think it depends on who's rearend we are talking about
    Ass, gas, or grass,no one rides for free
    My project 79'
  10. MadMike
    MadMike Administrator Staff Member
    13,620
    75
    Feb 11, 1999
    Dawsonville Georgia
    Go to a truck freight place.
    I shipped the back end of an IROC - 180# of steel from Atlanta to Chicago. One shipper I used once wanted $180 to ship it. I went down the street to another place and they took it for $40. Their terminal was in chicago. It went by air too. It stayed in chicago and the other fellow picked it up.
    If you want door to door service that'll cost a lot more.
    Bring the thing down to: BAX, ForwardAir, Roadway.... and ask them "how much to get this to <general destination>". Then ship it from the cheapest place. Whoever's getting the rear end will need to go pick it up locally at the terminal.
    I had the same thing with a 1980 nose. The place that took the steel wanted $150 to send it, but another place threw it onto their truck and told me to give them $20. It depends on where the thing is going, and if the other party agrees to pick it up at a terminal, not have it dropped off at their house.
