how much hp 355
Discussion in 'High Performance Modifications' started by quick79z, Jun 30, 2010.
  1. Nitroexpress
    Nitroexpress Veteran Member
    1,523
    Jun 1, 2005
    "Rochester" NY
    I have similar set-up and mines at 425
  2. Tokyo Torquer3
    Tokyo Torquer3 Veteran Member
    2,187
    Oct 14, 2003
    NJ
    I assume that is a solid FT cam?.. I am too lazy too look up the specs, so I will guess 450-470hp.
  3. quick79z
    quick79z Veteran Member
    393
    May 5, 2004
    saint john N.B canada
    sorry, its a solid street roller, 579/585,242/248,108 lsa
  4. Tokyo Torquer3
    2,187
    Oct 14, 2003
    NJ
    in that case 470-500hp. should be a healthy 355ci. why didnt you go 383, already had the crank and related parts?
  5. 79HumbleBee
    79HumbleBee Veteran Member Lifetime Gold Member
    522
    Feb 3, 2008
    Olympia, WA
    ditto, puttin my car on a dyno at an automotive school soon.
  6. quick79z
    393
    May 5, 2004
    yep, allready had the parts to build a really healthy 355 or would have gone with a stroker, not 383 more like 401 or bigger, have a 150 shot just incase its lazy
  7. quick79z
    393
    May 5, 2004
    quench 045, final cr 10.43:1,cam installed 105,this thing better work good
  8. 78camarodude
    78camarodude Veteran Member
    133
    Jun 20, 2010
    bennett,colorado
    Looks really good im guessing 450hp
  9. tallman1970
    tallman1970 Veteran Member Lifetime Gold Member
    1,315
    Jul 31, 2000
    Camas,WA
    Looks great quick79z,Good luck with the start-up and dyno pull.I would like some you-tube posts.
  10. quick79z
    393
    May 5, 2004
    well, if it runs strong i will post something,those heads flow around 308 cfm but im not gonna turn the engine high enough to take advantage of it, will stop the pulls at 6800-7000 even with the daul plane
