How much HP will this put out roughly?
Discussion in 'Engine Topic' started by Yellow Jacket, Feb 16, 2011.
  1. SKIP WHITE
    SKIP WHITE Member
    48
    Jan 4, 2010
    Kingsport TN
    240hp small intake, small cam, small carb, small heads, small valves.
  2. mrvedit
    mrvedit Veteran Member
    1,355
    Jun 12, 2009
    Ann Arbor, MI
    IMHO (and novice opinion) that wouldn't be a big improvement over what you have. Your intake manifold is fine. You really need to get new modern heads with 64cc chambers to get your compression ratio up; modern heads will also flow much better at all RPM, come with bigger valves and better springs, etc. With good heads you might be looking at 350hp, perhaps 100 more than you have now. (OK, probably need a 650cfm carb for that too.)
  3. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,155
    230
    Dec 19, 2008
    Yup, i have to agree!! 240 sounds about right. :happy:
