How not to make HP with a 427 BBC
Discussion in 'High Performance Modifications' started by 1980RS, Feb 14, 2020.
  1. 1980RS
    1980RS Veteran Member
    4,598
    1,303
    Jun 17, 2006
    MN
    I did use the bigger oval port intake (air gap), I also tried the Weiand peanut port intake dual plane intake and it worked really well 11.70's as I remember. I did try a ported oval port Strip Dominator but only got a couple of runs that day so the evaluation was not done. Will try it again with my 360 peanut port heads on the next 468. Oh ya, I did use one other single plane intake, it was the Procomp Eddy copy. While it did work pretty good the Air Gap was a touch better. Pretty much a toss up on those two. I have not used a square port intake on an oval port head since the late 70's. When I did the engine pretty much stalled out at 5K, put the old canted Torker back on and it would pull right up to 6500.
  2. 70RamAirIII
    70RamAirIII Pontiac-aholic
    62
    16
    Jan 10, 2005
    Calgary, Alberta
    I give you props.
    Unfortunately often people's eyes glaze over when you try to give them specifics, I would know, I try to do the same when ever selling stuff;
    It's the listings with very little info that seem to pique the most interest, and often people want to feel like their getting a deal over knowing the details.
    1980RS likes this.
  3. Plant Engineer
    Plant Engineer Veteran Member
    404
    108
    May 17, 2017
    Fort Mill SC
    I wouldnt use rectangular port heads on any 427 that wasnt 12:1 . 7 1/2:1 would be fine for a blower motor but thats about it. Who knows what it was built for originally. Could have been a blower motor that someone pulled the blower off and put a manifold and carb on.
  4. Z-Life
    Z-Life Member
    57
    25
    Oct 3, 2016
    Florida
    The engine will make 600HP on top fuel nitro for about half a mile, there I fixed it for the guy(snicker).
  5. jeff swisher
    jeff swisher Veteran Member
    1,699
    554
    Apr 26, 2018
    Yukon Oklahoma
    To the guy that took the heads off--leave the rockers on or at least two of em so you can grab it by them:)[/QUOTE]
    When I know I am pulling a head I remove all head bolts with rockers still adjusted. If you can get to the head bolts that is.
    9 times out of 10 the head will lift off the gasket from the rockers pushing on the pushrods.
    No need for the hammer screwdriver deal between head and block.
    cadillac_al likes this.
  6. badazz81z28
    18,903
    1,008
    Alabama
    I flinched too when I saw the screw driver and hammer...I was like really?!?!?
    jeff swisher likes this.
  7. jester1
    jester1 Veteran Member
    2,384
    Jan 12, 2005
    I have nothing good to say.
    They did another 427 on spray, I wouldn't let them touch a lawnmower after seeing that video.
