how often do u change ur oil and.....
Discussion in 'Competition Camaros' started by 79CamaroZ28, Dec 28, 2012.
  1. 79CamaroZ28
    79CamaroZ28 Veteran Member
    1,243
    Aug 1, 2001
    tucson, Arizona
    What is acceptable in the filter when you cut it open? My 436 sbc has 3 oil changes and 2000 miles on it now and I'm still getting little stuff in filter. It's not magnetic and its not much maybe a little piece of alluminum dibris here and there. Motor previously ate a alluminum Timing cover and rod bearing and was washed out pretty good but you never can trust they got it completly clean. This oil change has 500 street miles on it with some out in the middle of nowhere testing. A little paranoid because its my first big inch sbc. What do you think??
  2. red78z
    red78z Veteran Member
    2,353
    Sep 12, 2009
    pottsville,pa.
    i only change the oil in the camaro once a year , but i dont even average 100 miles a year right now
  3. Philip
    Philip Veteran Member Lifetime Gold Member
    1,808
    May 30, 2006
    Marana, AZ
    Unless the engine was completely torn down after the cover incident and all the oil passages cleaned with a brush and solvent there still may be aluminum floating around. Use a filter adapter with a plugged bypass to allow the filter to catch all the particles.
    Mine is changed 3000 - 5000 miles, about 3 times a year. I use Wix (NAPA Gold) filters, Brad Penn oil and have never found any metal in the filter. The oil bypass valve was blocked off during the rebuild to insure all oil was filtered 100% of the time. If something does happen the debris should all get trapped in the filter.
    Daily drivers gets changed when the oil change indicator gets to zero. Wix filters are used and the GM recommended oils.
  4. fuzzy dice
    fuzzy dice Veteran Member
    651
    Apr 16, 2008
    Deltona, Fl.
    For the drag racers, I change mine every 70 passes....that's about 9 miles since I run 1/8 mile...Valvoline VR-1 and Napa Gold filter...
  5. sponge003
    sponge003 Veteran Member Gold Member
    1,510
    Jan 10, 2009
    Concord, NC
    Drag only 50- 70 passes and wix filter, royal purple 10 w 40
  6. 79CamaroZ28
    1,243
    Aug 1, 2001
    tucson, Arizona
    I do have a billet Canton filter adapter so no bypass. I'm gonna just run it, after talking with builder I'm just being paranoid.
  7. CorkyE
    11,428
    932
    LOL - same here...
  8. Rich Schmidt
    Rich Schmidt Veteran Member
    4,285
    40
    Mar 27, 2010
    Denville NJ
    My race car,I change it 2 or 3 times a year. I always start the season with fresh oil,and I change it about halfway thru the season. I put about 150 runs a year on it. I also have gapless rings and a vacuum pump,so the oil gets almost no contamination in it. I run a Moroso race filter with no bypass. If I had to worry about 1 thing,it would be condensation from short running cycles. The oil can be a bit clouded at times,but always gets crystal clear when the engine is hot. Even at it's worst the oil is still transparent. Too much condensation in the oil can cause the paper fibers in the filter to expand and cause restriction.
  9. HOLESHOT
    HOLESHOT Veteran Member
    1,043
    Feb 19, 2009
    mesa,az
    I change mine every 2 or 3 races so about 4 passes on a good weekend for my sorry but lol..I have a massive amount of blow by and oil gets nasty fast
  10. 71flh
    71flh Veteran Member
    1,001
    29
    Jun 1, 2010
    DFW
    Time, miles, runs, etc.
    3 months?
    3000 miles?
    X runs
    Y years?
    We need a vote!
