How to Bleed Coolant
Discussion in 'Troubleshooting & Diagnosis' started by motor60, Nov 18, 2011.
  1. motor60
    motor60 Member
    85
    Feb 27, 2011
    So. Cal
    How do you bleed coolant to get all air pockets out?
  2. frankz
    frankz Veteran Member
    2,107
    21
    Aug 24, 2009
    Illinois
    I find the best method is to fill the motor thru the t/stat housing and then fill the rad.
  3. Fbird
    4,461
    834
    Feb 12, 2011
    atlanta, ga
    ^^^^burp^^^^
  4. Twisted_Metal
    27,546
    1,242
    Fill, run engine until warm (radiator cap off), refill.
    I have little holes drilled in my thermostat so air doesn't get trapped in the engine.
  5. High Country Z
    High Country Z Veteran Member
    1,353
    Jun 28, 2009
    N.Central Pennsylvania,
    Raising the front of the car slightly with a floor jack with the cap off while it's running will help if it's stubborn to get all of the air out.
  6. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,076
    14
    Sep 22, 2007
    Blind Bay, B.C.
    That's got to be the best tip. When filling it with the t-stat housing off too, (with engine not running of coarse).;)
  7. motor60
    motor60 Member
    85
    Feb 27, 2011
    So. Cal
    How do I know if I got all the air out?
  8. COPO
    18,815
    1,211
    When it stops the burps. You'll eventually see the water running through the cores.
  9. Philip
    Philip Veteran Member Lifetime Gold Member
    1,807
    May 30, 2006
    Marana, AZ
    The air will naturally bleed out itself. Chevy engines have thermostat bypass ports it is just a slow process. One or two heat cycles will have all the air out if there are no leaks in the system.
  10. motor60
    motor60 Member
    85
    Feb 27, 2011
    So. Cal
    ok, car cooled down to approx. 190 but still heats up to approx. 220 when driving around. Then starts to cool at idle again. Weird, but why does it do that?
