How to determine if a 73 Z28 Camaro has the LT option also
Discussion in '1970 - 1973 Specific' started by camarozbest, Jan 25, 2019.
  1. camarozbest
    camarozbest Member
    59
    Mar 13, 2009
    Michigan
    Is there any way to tell on a 1973 Z28 if it also had the LT option the fifth digit of the Vin.# T
    The Trim tag Reads
    TR 773 A51 75 75 PNT
    05D Z28
    590077
    When I look at the Camaro white book it has the 773 interior under the LT list.
    Thanks
    Dave
  2. Twisted_Metal
    30,187
    2,893
    Second digit of the VIN should be as “S” for an LT.
    The “T” tells you it’s a 350.
  3. camarozbest
    camarozbest Member
    59
    Mar 13, 2009
    Michigan
    Thanks for the reply so here is the Vin.# 1S87T3N17XXXX with this information if I understand correctly this is a 1973 RS/Z28 LT
  4. twozs
    twozs Veteran Member
    8,817
    174
    Aug 5, 1999
    hopewell jct ny
    it wouldn't tell you if its an RS or not but it is a model Type LT with the Z28 option . the T is for the " special performance engine Z28 " . there were 3 different 350 ci engines available with different designations
  5. camarozbest
    camarozbest Member
    59
    Mar 13, 2009
    Michigan
    Thanks for the reply's it does have the RS front end, I bought this project as a roller with no interior and missing the instrument cluster I new the T in the Vin. designated Z28 but when I looked up the interior code 773 it said type LT i just didn't know how to prove it. Thank again everyone.
    twozs likes this.
  6. twozs
    8,817
    174
    Aug 5, 1999
    hopewell jct ny
    any Picts of the car ?
  7. McCune
    McCune Veteran Member
    1,390
    379
    Aug 22, 2015
    st.george utah
    There are a lot of tell tell signs if it is a true 73 RS. Throw some pictures up of the core support.
  8. f-body freak
    f-body freak Veteran Member
    483
    223
    Nov 22, 2014
    northern ohio
    Saweeet!:bowtie: Another 73Z28 Type LT. I wish we knew how many of the 11,000 Z28s were made with the Type LT option...
  9. wiseryder
    2,270
    105
    Sep 11, 2004
    belding,mi USA
    Mine is a true LT Z28 as well
  10. greeny
    greeny Veteran Member
    225
    18
    Feb 21, 2005
    arizona
    Here is a pic of my Type LT Z28 4spd 6B44505E-0CD0-4E11-80DF-9C85BE465910.jpeg
    Lindsey, 73rsltz and f-body freak like this.
