How to - Headlight Relays
Discussion in 'Electrical Systems' started by BonzoHansen, Oct 12, 2007.
  1. earnhardtgm3
    earnhardtgm3 Veteran Member
    4,085
    51
    Dec 18, 2007
    Camaro Country,GA
  2. falloutboy
    falloutboy Veteran Member
    2,283
    15
    May 1, 2003
    Grafenberg, Baden-W├╝rttemberg, Germany
    u might now wanna check the beam pattern and orientation of the headlights, to get the most out of it, and don't blind oncomming traffic.
  3. daniel76309
    daniel76309 Veteran Member Lifetime Gold Member
    935
    Oct 22, 2005
    Niceville, Florida
    Mickstan and earnhardtgm3, you may want to consider an alternate location for your relays. Where they are, they are going to get rained on, which could eventually cause problems.
    How do I know?--I made the mistake of mounting a fan controller (which was supposedly waterproof) in a similar location. I think if relays see a lot of water, they may in time have problems also.
  4. mickstan
    mickstan Veteran Member
    927
    Jun 11, 2012
    E'ville, IL
    Thanks for the heads-up Daniel! But that is no worry for me, my car hasn't seen a real rain since 1992!
  5. Leonards78LT
    Leonards78LT Veteran Member Lifetime Gold Member
    1,031
    Jan 21, 2001
    Central Oklahoma
    Mine too. I wish I would have done this years ago. I already had my fuel pump power being feed off the battery output of the alternator and 10 ga. wire back to the pump itself, inside of the wimpy 14 ga. that is normally used.
  6. hot72rod
    3,019
    39
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    Old thread I know, but one question. Is this for the stock head lights or for aftermarket head lights like one that uses the H4 bulbs?
  7. 73 Z
    1,139
    71
    Jun 9, 2007
    Los Angeles, Ca
    I would say it's for anything that's ran through a switch. Headlights, pumps, windows, etc. Stock or aftermarket.
    falloutboy likes this.
  8. COPO
    20,375
    2,163
    You can use it on stock lights to releave the work on the head light switch.
    E80B8136-7F70-4454-88DB-AA8A5C653DDD.jpeg A099A740-93EA-461C-B742-7259A9871078.jpeg
    Rene Melten likes this.
