How to remove 70Z28 accelerator pedal bracket
Discussion in '1970 - 1973 Specific' started by Rusty Mc, Mar 28, 2020.
  1. Rusty Mc
    Rusty Mc New Member
    28
    Dec 11, 2019
    Can someone tell me if the nuts are welded to the floor pan?
    What the best way of removing this bracket so i can put above new carpet?
    Thanks
    Rusty
  2. twestrup
    twestrup Veteran Member Lifetime Gold Member
    260
    137
    Aug 22, 2018
    St. George, Utah
    Nuts are not welded to the floor pan. Loosen from the outside, spray some WD-40 on them first.
  3. Rusty Mc
    Rusty Mc New Member
    28
    Dec 11, 2019
    Great, thanks for your rely!
  4. COPO
    19,877
    1,837
    You will need a second person to push the bracket from inside when you go to install the nuts.
    Rusty Mc likes this.
  5. 70lt1z28
    4,029
    897
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Just don't try taking the studs off the inner plate! Even though they have a hex for a socket, they are resistance welded (at least mine are) to the plate.
  6. Rusty Mc
    Rusty Mc New Member
    28
    Dec 11, 2019
    FYI, there is a metal screw between the studs that i used to draw down the plate front inside.
    I just used a long screw to do this process.
    It worked out perfect and solo. Thanks
