How to remove deck lid hinge and pin 72 Camaro
Discussion in 'Body Restoration' started by lapedr, Apr 10, 2018.
  1. lapedr
    lapedr Veteran Member Gold Member
    668
    23
    Jan 28, 2003
    Pembroke, GA
    If anyone has ever removed a deck lid hinge and pin from its strap on a 70-81 Camaro? I already have the torque rods out, and deck lid off. The pin that keeps the hinge in the strap will not come out, and I don't want to cut it out. It moves side to side about 1/8" but that's about it. Any ideas?
  2. berg2695
    berg2695 Veteran Member
    450
    123
    Nov 13, 2011
    AUBURN, WA
    As you probably already know, the pins are flared on one end and have two tabs on the other end that are bent outward to retain it in the hinge. Once the tabs are straightened, the pin should tap out. However, if the hinge has worn into the pin over time and formed a groove, you may have to manipulate the hinge strap in various directions while tapping with a hammer. Good luck.
  3. lapedr
    668
    23
    Jan 28, 2003
    Pembroke, GA
    THX that's what I thought but I wanted to make sure before I started pounding with a hammer
