How to remove these coat hanger holders?
Discussion in 'Interior Restoration' started by latvius, Nov 24, 2021.
  1. latvius
    latvius New Member
    Sep 30, 2021
    Hi I have a 73 camaro and am not sure what they are but I can't see how to remove them, they are helping to hold the headliner up.
    Any advice would be greatly appreciated!
  2. GoldenOne7710
    5,612
    894
    Jun 23, 2004
    Athens, GA
    Isn't there a recessed screw in it? It may be the same color as the plastic and hard to see.
  3. Jim Streib
    Jim Streib https://www.flickr.com/photos/[email protected]/albums
    484
    109
    Apr 6, 2004
    Saint Louis, MO USA
    If these covers are like on my 73 Nova, the plastic cover is hinged and molded to some plastic under the mounting surface to where 3 edges will not be attached and you want to pry the top cap portion off directly opposite where the plastic wraps around to the backside.
    Once the cover is hinged open, the bolts should be visible and be able to be removed.
    Just be careful as the plastic may be brittle and/or easily scratched.
    You might have to work some of the seat belt through the opening to get the plastic to hinge open enough.
    https://www.camarocentral.com/1968_1973_Camaro_Shoulder_Seat_Belt_Roof_Anchor_p/int-376.htm?CartID=1
    Jim
  4. latvius
    latvius New Member
    Sep 30, 2021
    I'll look for a screw tomorrow. I didn't think it had a 3 point belt but I did not remove them and I don't think I have the front seat belts. Would be interesting in seeing how it connected originally though.
  5. BillyDean7173
    BillyDean7173 Psychopathy Red
    3,100
    1,150
    May 21, 2014
    Hutto, TX
    Those are not factory coat hangers for a 73 Camaro. In mid or late 73, there was a switch from bow headliners to board headliners. The sail panel changed also. The earlier 73 sail panel just had a plain wide hook. Then the mid to later 73-74 had a cut out for a bezel and a hook.
    I'm not sure what type of headliner you have. Take a look at my ad in the Swap Meet forum (I think on page 3). There's a set of 73-74 sail panels for a board headliner I sold that has a pic of the hangers.
    Also, the 73 did have the 3-point seat belt system. One retractable lap belt between the door and seat, one buckle between the seat and console (if you had one), and a non-retractable shoulder belt. There was a plastic shoulder belt retainer on the headliner rail above the door. The retractor has wiring in it for the seat belt warning light on the lower dash and a sensor under the seat.
    latvius likes this.
  6. latvius
    latvius New Member
    Sep 30, 2021
    That helps thanks!, I have a board type headliner btw
  7. latvius
    latvius New Member
    Sep 30, 2021
    Figured out how to remove them, so yeah not coat hangers looks like seat belt attachments to me.
  8. BillyDean7173
    3,100
    1,150
    May 21, 2014
    Hutto, TX
    Yep, those are the shoulder belt anchors like Jim said. Guess I couldn't tell by the first pic so my bad. I'll post a pic of mine when I get home.
    latvius likes this.
  9. BillyDean7173
    3,100
    1,150
    May 21, 2014
    Hutto, TX
    Here's a pic of the shoulder belt anchor. Hopefully, you can make out how the belt loops in the middle of the anchor. I've also included some pics of the seat belt itself. The buckle is often called an exploding seat belt because the housing cracks and the parts go flying, lol. There are some kits available on ebay. There's a 1st and 2nd design kit, which I wasn't aware of.
    20211125_203020.jpg 20211125_203216.jpg 20211125_203448.jpg 20211125_204040.jpg 20211125_203322.jpg 20211125_203341.jpg
    latvius likes this.
  10. latvius
    latvius New Member
    Sep 30, 2021
    OK so the actual belt goes through it, thank you for the pictures! I see the coat hangers in the background and mine did not have any, at least it doesn't have any now :)
    BillyDean7173 likes this.
