How To Rotate Engine Thats Been Sitting
Discussion in 'Engine Topic' started by szalkuskt, Mar 28, 2016.
  1. OldCamaroNut
    OldCamaroNut Veteran Member Gold Member
    948
    Apr 27, 2005
    Rancocas Woods, NJ
    If you have an old distributor laying around you can make your own oil primer for free. Knock out the drift pin that holds the cam gear on, remove the gear, and it's ready to go!
  2. 77Z28454
    77Z28454 Veteran Member Lifetime Gold Member
    105
    13
    Aug 24, 2007
    Ontario
    I had basically the same circumstance as you very recently. All my spark plugs were in but my engine was stored in a somewhat damp barn. I bought one of those inspection cameras used of craigs list ($40) and looked in the cylinders with it. All of mine were in perfect condition. I haven't started the motor yet but it's nice being confident the cylinders don't have corrosion.
  3. szalkuskt
    szalkuskt Veteran Member
    1,368
    Aug 13, 2005
    Honolulu, Hawaii USA
    i see. thats good to know. do any of you guys have examples of borescopes that you have used and would recommend?
  4. MyBoTy
    MyBoTy Veteran Member
    1,567
    9
    Feb 9, 2002
    Lubbock, Texas USA
    Don't get the cheapie from Hazard Frought, the tip is too big to fit through a spark plug hole. I found mine on sleazebay, it was one of the more expensive Hazard Frought models with the smaller tip that the guy bought and used once, I paid $80 and it works great.
  5. badazz81z28
    18,658
    951
    Alabama
    depending on the environmental conditions, it may just need an oil prime and go. Just because its been 8 years doesn't mean its frozen, ring rusted to the cylinder bores etc. I have seen engine sit for a month and get rusty inside. I agree, take a BS and look inside. If its clean, shoot some oil down there and rotate the engine to make sure its free.
  6. 77Z28454
    105
    13
    Aug 24, 2007
    Ontario
    The one I bought used is King Canada model KC-9050. I realize that doesn't help you much being Canadian but you can see the specs etc. If I was buying a new one I'd probably get one of the ones that attaches to a smart phone. They are inexpensive on Amazon and if you have smart phone it makes sense to me.
