How would you build a 10 bolt for cornering?
Discussion in 'Transmission & Driveline Topics' started by LT1 WS6, Nov 22, 2014.
  1. LT1 WS6
    LT1 WS6 Veteran Member
    510
    May 25, 2009
    Sandy Springs, GA
    I appreciate you speaking up. I do. That's what I think these forums are all about and makes them great. I'll double check myself since I just learned that info from gear head.
  2. big gear head
    big gear head Veteran Member
    6,398
    172
    Jul 30, 2001
    Central City, Ky.
    The 8.2, 8.5 and 12 bolt all use the same brakes, axle bearings and seals. The axle hang out on the Chevy rear ends is 2 3/4 inches. When you order a rear end from Moser they will ask you what brakes you are using and they will build the rear end for those brakes. The 9 inch Ford usually has 2 1/2 inches of axle hang out, but they build it with 2 3/4 and the 7900 housing ends when Chevy brakes are being used.
