HVAC knobs
Discussion in 'Interior Restoration' started by camarolife78, Aug 8, 2015.
  1. camarolife78
    camarolife78 Veteran Member
    549
    Jul 22, 2014
    Gardner, KS
    I bought a new HVAC control panel since all of the screw holes are broken in my original. Is there a trick to pulling the knobs off? I have tried pulling on them, and using pliers with a rag covering them.....no go. Any tips, advice, suggestions, etc?
  2. grzewnicki
    3,580
    283
    Dec 9, 2009
    Gordon from Jacksonville Fl
    From what I've seen on other GM cars, the end of the lever has some teeth or an arrow shape to it. Pliers and a rocking motion should do it. It is the rocking motion that will do the trick just pulling straight out won't work..
  3. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    Using a tool that has a 90* bend on it so you can get behind the knob and pull.
    We had to pull a lot of knobs off when we installed AC so we could change the face plates.
  4. CamaroDoc
    CamaroDoc Veteran Member
    2,251
    266
    Sep 13, 2003
    Skiatook, Okla. 74070
    I have changed several faceplates without removing the knobs at all... Separate the levers about an inch and a half apart and centered in their sweep. Then using a screw driver you can gently spread the opening and start to lift the faceplate over the knobs. You have to do all the knobs simultaneously and work slowly and gently a little bit at a time.
  5. camarolife78
    549
    Jul 22, 2014
    Gardner, KS
    Thanks, I will try those things out!
