hyd roller lifters
Discussion in 'High Performance Modifications' started by 80'427, Jul 31, 2009.
  1. 80'427
    80'427 Veteran Member
    1,886
    Jan 1, 2005
    Fairbury, NE, USA
    I am converting one of last years circle track engines into tow duty in my 84 k10. I have to change the cam so I was going to use my retro fit hyd roller in out of the current 355 (since it is going into circle track duty). The only hitch is the 383 I am putting in has ford lifter bores. Will a retrofit ford hyd roller work or do I have to get some super high dollar custom lifters?
  2. Lowend
    16,457
    1,261
    Mar 25, 1999
    San Jose, CA, USA
    Oof, I'm pretty sure the Ford lifters are different (bore spacing ect)
    You are probably looking custom.
    I hate to say it, but a flat tappet is probably a better way to go on this one.
    Use a flattappet specific oil l like Joe Gibbs to make it last. Crower now has a "cam saver" lifter with an oil channel cut in it to improve flow, probably not a bad investment
  3. Louich
    Louich Veteran Member
    2,415
    Mar 8, 2004
    Arthur, Ontario
    you would use your roller chev cam but use the ford roller lifters cause the lifter bore dia is bigger. not in a diff location. or have bushings installed in lifter bores to run your chev lifters
  4. AJ_72
    AJ_72 Veteran Member
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    I would think you can't use Ford roller lifters because the bore spacing is probably a different distance between lifters. Finding a lifter with the Ford diameter and the Chevy cross bar spacing probably isn't going to be something off the shelf.
    Lowend's advice is the best here. A flat face Ford lifter will be the cheapest easiest way to get 'er done.
