hyd vs solid roller
Discussion in 'High Performance Modifications' started by HULKZ28, Apr 26, 2009.
  1. HULKZ28
    HULKZ28 Veteran Member
    1,572
    Oct 15, 2005
    Jeffersonville NY USA
    I thought it was time to freshen up this discussion on using a solid roller in a street driven car..
    I get some varying opinions here and really dont want to destroy my motor because of a bad cam choice...Id sell the solid kit to offset the cost of a hyd roller if need be.
    Is a hyd roller easier on parts??I think ill be in the high 500s on lift mabey 570..With the option to run 1.6 rockers to up my cam size a bit , later on..Duration will probably be around [email protected] with a 108 lsa mabey 106..
    thanks
  2. CorkyE
    11,374
    902
    Hydraulic roller is the way to go on the street, as many have said. The maximum amount of lift you can go with will be determined by your head/spring combo, but remember that bigger is not always better on a street driven engine. Lastly; why 1.6 rockers? Just buy the correct cam. IMHO
  3. cmonson
    cmonson Veteran Member Gold Member
    4,134
    Apr 7, 2006
    Calgary, Alberta
    Hulk, if I remember right you have very close to the same engine combo as myself. 10.5:1 compression, vortec heads, bla, bla, bla... My engine has no issues buring the tires cruising in 2nd gear to a WOT.
    I currently am using the cam below (I know flat tappet) but it has been a great performance piece without the costs of a roller. Just something to consider.
  4. HULKZ28
    1,572
    Oct 15, 2005
    My 355 runs very good with the solid I have in it, im done with that motor....This new cam will be going into a 422 that is in the build process now...I will be getting heads in the 220-230 range for it..im looking for massive torque,
  5. LILRED496
    LILRED496 Veteran Member
    1,211
    Jul 14, 2008
    FLA
    You said you not gonna spin it past 6000 so a hydraulic roller would be your best bet.
    I have a hydraulic roller in my 496 and spin it up to 6300 sometimes.
    Ive had the 496 running for two years now I have enough miles on it that I would probably be thinking of replacing my lifters if they were solids.
  6. scrapmetal
    scrapmetal Veteran Member Lifetime Gold Member
    1,852
    108
    Jul 5, 2007
    Cleburne,Texas
    Replace them.
  7. cmonson
    4,134
    Apr 7, 2006
    Calgary, Alberta
    well above all said. Unless the car were a strip only car and I wanted to go roller, I would deffinately be going to hydro for a street setup. For a strip I would deffinately go solid.
  8. LILRED496
    1,211
    Jul 14, 2008
    FLA
    Replace what? My hydraulic lifters?
  9. ADV1
    ADV1 Veteran Member
    142
    Jan 7, 2004
    Lincoln, NE 68522
    Install a REV kit and get a little more RPM out of them... You'll be able to pull double duty with ease...
  10. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    Use the correct springs, a "rev kit" is unnecessary.
    My HYD Roller sees its 6500 through the lights without a missed beat.
    Solid will still be a lighter lifter and a more aggressive cam lobe, unless you can get a street series of Solid roller cam with a calmer lobe like a HYD roller cam has. The HYD Roller cam is still way more aggressive than a flat tappet HYD cam which why they work so well with having 10ยบ less DUR at 0.050" lift vs a FT HYD cam.
