Hydroboost Help...
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by mjoc, Apr 24, 2020.
  1. mjoc
    mjoc Veteran Member
    3,534
    Apr 29, 2003
    Sherman Oaks, Ca
    Ordered and just received my hydroboost unit and it doesnt have instructions on how to hook up the hydroboost lines.. I would like to do this, this weekend I need help to know which lines go where etc... THanks in ADvance
    Michael
  2. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,645
    1,060
    Mar 27, 2016
    NY
    Which unit did you get? There area a couple of threads on here of people installing these units, try a search for Hydroboost , one the site and see if they come up, and call the people that you bought it from and ask for the install instructions, it works like a steering box, high and low side, you just want to make sure you hook it up right, so you don't make a mess, HAA HA , if the line blows off
  3. mjoc
    mjoc Veteran Member
    3,534
    Apr 29, 2003
    Sherman Oaks, Ca
    I went with a company called ABSpowersteering.. I got a chrome unit with a wilwood master there three hose connection I ended up watching a lot of you tube videos and I think i figured it out. but I will use the search feature now too.
    Michael
  4. dave@ztech
    4,645
    1,060
    Mar 27, 2016
    NY
    I didn't think that that system used a master? I thought it ran on hydro fluid, from the power steering, right?
  5. CorkyE
    11,315
    877
    Hydro boost, from power steering, replaces the vacuum booster. You'll still have a master cylinder.
    [email protected] likes this.
  6. biker
    biker Veteran Member
    3,556
    1,625
    Dec 7, 2014
    It eliminates the big brake vacuum booster, but the master still has to be there to pressurize the brake lines and work the calipers/drum cylinders.
  7. dave@ztech
    4,645
    1,060
    Mar 27, 2016
    NY
    Shows what an idiot I am, HAA HA , so it's like a regular system except the hyrdo provides the boost, and you need all the other regular brake lines and parts, got it!!
  8. Jodi
    Jodi Veteran Member
    824
    542
    May 22, 2019
    Find the pressure line from the Power steering Pump... the Hydro boost unit just hooks in series to this line.
    Check out my Project Progress Thread "My '73 Pro Street Project". Did this Mod. to my car a while back.
  9. biker
    3,556
    1,625
    Dec 7, 2014
    Trust me...before I got to see one in a shop I worked at many years ago, I thought it was some weird sorcery too.
    mjoc and [email protected] like this.
