I changed the oil...and..
Discussion in 'Competition Camaros' started by vegas1974z28, Jan 25, 2016.
  1. muscl car
    22,175
    973
    Jul 8, 2001
    SoCal High Desert
    Mattie sent me pics of the lifter valley a couple days ago and with the pics enlarged I couldn't see anything wrong with the roller lifters , push rods or cam lobes .I even asked about the distributor and he mentioned there was no damage
  2. mrdragster1970
    7,821
    507
    Apr 12, 2007
    I was just wondering if there was bouncing damage to the pistons???
    I borrow my buddies boroscope, maybe you can borrow or rent one just to have piece of mind.
  3. RacerRick
    RacerRick Veteran Member
    1,641
    Jul 18, 2003
    Toronto, ON, Canada
    Check the timing set if it has a roller timing set. I have seen the rollers come apart and look like that, and that one piece looks like the tip of a timing gear.
  4. vegas1974z28
    4,661
    123
    Jan 10, 2002
    Las Vegas,NV
    OH my i never thought of that.....it does look like a gear.
  5. DB Z28
    DB Z28 Veteran Member
    580
    47
    Nov 30, 2003
    Fond Du Lac
    It does look like the timing chain and gear teeth parts
  6. APEowner
    APEowner Veteran Member
    646
    12
    Dec 9, 2013
    Albuquerque, NM
    I do believe that RacerRick nailed it.
  7. vegas1974z28
    4,661
    123
    Jan 10, 2002
    Las Vegas,NV
    Yep, looks that way and machine shop verified...
  8. 81 Sport Coupe
    81 Sport Coupe Veteran Member
    246
    Nov 27, 2012
    Batavia, NY
    guessing valve keeper??? lol had me wondering at first how a golf ball would come out of the oil pan.
  9. vegas1974z28
    4,661
    123
    Jan 10, 2002
    Las Vegas,NV
    timing chain started coming apart...gear teeth broke, no other damage.....new gear ,check bearings, drop oil pan, and put her back together.... :)
  10. mrdragster1970
    7,821
    507
    Apr 12, 2007
    Get a jesel cheap skate :p
