I f'ed up... bad!! Please help 1990 chev pickup rear glass replacement
Discussion in 'The BS Topic' started by bigblock665, Apr 22, 2011.
  1. bigblock665
    bigblock665 Veteran Member
    1,053
    Apr 7, 2009
    NY
    I had a good day today... got my camaro running good, nothing could bring me down... Until tonight.
    I picked up some steel pipe from a friend with the truck my pops let me borrow.
    I shoved a piece of pipe a little to hard and it slammed the rear windshield on the truck! Cracked it all to hell....
    Now i need to make it right and replace it.
    does anybody know the process of replacing this glass?
    I know this is not a camaro but I could not find any help anywhere else.
    Google comes up with everything but what Im looking for.
    Does this glass have just a seal or is it glued???
  2. dammitmitchell
    dammitmitchell Veteran Member
    267
    Feb 19, 2011
    san angelo. tx
    you can call a junkyard and have them pull the glass for you..
    and have someone install it..
    safest bet on a truck
  3. Chevrolaine
    Chevrolaine Veteran Member Gold Member
    3,368
    195
    Aug 5, 2007
    Various barns in N. IL looking for chit.
    Pretty sure it's just a seal. Can't imagine it's over $150 installed.
  4. bigblock665
    1,053
    Apr 7, 2009
    NY
    ok I was told there is the same truck in the junkyard with good rear windshield. So its just a seal? No glue? And do I remove the black seal with a flat tip screw driver or a plastic wedge? Do I start the removal in one of the corners?
    I just want to be sure because im going to my local salvage yard in the morning.
    Thanx again!
  5. Knuckle Dragger
    16,576
    2,894
    Nov 2, 2002
    Waddell AZ
    I think they went a urethane "glue" seal with the body change.
  6. DentDude
    DentDude Veteran Member
    417
    Apr 15, 2011
    Columbus,Ohio
    Yep,its a urethane glue,I just had a glass guy do mine a couple months ago on my 1990 Silverado. I highly reccomend you have a professional do the job,because that stuff is like concrete!!
  7. bigblock665
    1,053
    Apr 7, 2009
    NY
    I notice it has a rubber seal all the way around the rear glass. Did gm use a seal and urethane glue?
  8. Knuckle Dragger
    16,576
    2,894
    Nov 2, 2002
    Waddell AZ
    There should be rubber trim with the urethane. Try and get a look at it inside the truck.
    I remember I was working for a retailer that installed sliding windows back in the late 80's. We gave free sliding windows to a good number of the "new" Chevy truck owners to bribe them into letting us use their truck in a training class on how to glue the windows in place.
    That was over 20 years ago so I'm reluctant to claim it as fact, but I'm pretty sure it's glued.
  9. bigblock665
    1,053
    Apr 7, 2009
    NY
    Thanx guy's... Yall just broke my heart! lol Sounds like a job!!! O well thats what I get for being careless...
    Thanx for all the reply's, Ill asses the situation in the am and see if I could do it myself. Hey look on the bright side, Ill get to learn something new!
  10. bigblock665
    1,053
    Apr 7, 2009
    NY
    found this on lmctruck.com> The rear window on 1988-98 Chevy trucks is attached with urethane adhesive. Professional installation is required. Contact your local glass installer for installation...
    Can someone kick me in the nuts? I think it will hurt less than this glass issue.. or will help that pain go away.
    If I were to do this job myself what advice can yall give me (besides take it to a professional) I just cannot afford it at this time to have a pro do it for me.
