I Need Engine Code Suffix Help
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by 1stSecondGenFbody1970, Sep 28, 2020.
  1. 1stSecondGenFbody1970
    1stSecondGenFbody1970 New Member
    Sep 28, 2020
    Hello everyone. New member, first post. I have a center bolt valve cover 350 cid I need help decoding. I've spent some time and can't find this specific Engine Suffix Code listed anywhere online. I can tell it was built in Flint on June 14th but I'd like to know what year of manufacture. Thanks in advance for any help on insight.
    Back of block: 14093638 so it's a 350, 2 or 4 bolt main, 1987 to 1995. One piece rear main seal.
    Front of block: V0614PHJ I understand the V0614 but what does the PHJ indicate?
  2. Rosster
    Rosster Veteran Member Gold Member
    213
    100
    Mar 1, 2020
    The 3 digit letter code tells the engine size and hp rating. For example a 1970 CTB is a 350ci 360hp LT-1. The code combinations have been reusEd over the years but with the casting year, you can figure out what it is.
    2ndGenCrazy likes this.
  3. l16pilot
    1,933
    171
    Dec 13, 2004
    Hurlock, MD, USA
    Code PHJ should be a 1988 350, 190 hp w/ TBI for a truck application
