I need help - Water Heater
Discussion in 'The BS Topic' started by gordonquixote, Nov 22, 2015.
  1. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    Check the settings on they tank. The temps are adjustable.
  2. Twisted_Metal
    30,054
    2,780
    Doable this way.... But MESSY!
    Manganese or iron in the water will stain those old towels forever!
    BTW.... What's a "HWH"?
  3. Mike N
    3,000
    722
    Jan 13, 2002
    Spencerport, NY.
    Hot Water Heater.
  4. goofnrox
    goofnrox Veteran Member
    248
    29
    Nov 26, 2003
    Grand Rapids, MI , USA
    Why would you want to heat hot water?
  5. danbrennan
    danbrennan Veteran Member Lifetime Gold Member
    4,342
    1,214
    Mar 13, 1999
    Brighton, MI
    To get it hotter, of course :crazy:
  6. krabben1
    8,262
    76
    May 16, 2007
    ( . Y . )Delco
    They tried calling it a cold water heater in the beginning,but they weren't selling.
    No one wanted hot cold water.
  7. Dave Nelson
    Dave Nelson Veteran Member
    5,386
    4,753
    Dec 19, 2003
    Vineland N.J USA
    Hot water storage tank?
  8. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    3,098
    275
    Jul 31, 2001
    Ft. Lauderdale, FL
    I've replaced elements before....and it's MUCH EASIER if you leave the water in You need the weight to be there when you go to wrench that old element out. My mom drained hers before I got over to her house and the thing wanted to move and dance all over the place from the force trying to remove the element
  9. sprink
    sprink Veteran Member
    581
    186
    Apr 27, 2008
    ffx, va
    Sorry, late to the party. You may have it fixed by now.
    Sounds like you fried the top element by turning on the power before heater was full. Doesn't take long. Power off, disconnect element wires & give it a continuity check. If good, check bottom one. Turn off power before taking panel covers off. Safer just in case screw, panel or you slip! They can also be tested by leaving hot wire hooked to one side of element & with other side unwired, check for power going through element.
    The socket sometimes will just round the flats on the element. I've taken a hammer & chisel/screwdriver & smacked the flats in a loosening direction to get it move. After that, it'll come right out unless it's been leaking.
    Careful doing it w/ water in it if you're over or near a finished area (vs. unfinished bsmnt.). Sometimes the element is deformed & won't come right out. Not a fun fight w/ 50 gallons of water gurgling behind it! If floor drain nearby, build a towel damm/funnel to direct the water to it just in case.
    Good luck.
