If you were my right front shock...why would you break?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by biker, Sep 12, 2021.
  1. Twisted_Metal
    29,962
    2,715
    I’m still not sure how a shock “bottoming out” would break the rod on the top unless there was some sideways movement too.
    Shock rods are very hard but they can be broken if you bend them sideways.
    (I’ve used that fact to remove stubborn ones with a rounded nut on top.)
    Possibly a stress crack from when it was manufactured and threaded?
  2. biker
    biker Veteran Member
    3,798
    1,793
    Dec 7, 2014
    I got thinking about that today as well while swapping out the rad on a giant Detroit Diesel.
    If the shock rod only operates in a strictly linear plane, I would think the shock body would blow out long before the rod breaks. Maybe there is a slight shearing that takes place under full bind. Wouldn't take much for a hardened rod to bust when subjected to force in a plane it wasn't designed to withstand.
  3. carr911
    carr911 Veteran Member
    4,021
    4,560
    Mar 4, 2016
    Tampa, FL
    Bilsteins are Warrantied for Life ( Original Purchaser)
  4. biker
    3,798
    1,793
    Dec 7, 2014
    Thanks man!
  5. Ratty_81
    Ratty_81 Veteran Member
    183
    100
    Nov 13, 2020
    Definitely a bending stress component there. Not much, but it's there. The lower control arm travels through an arc so it puts a bending load into the shock as it travels. The dog bone on the bottom "should" aleviate most of it, but if it's seized or binding it could cause more bending. I'm guessing it snapped off where the threaded portion is friction welded to the shaft?
    G72Zed likes this.
  6. biker
    3,798
    1,793
    Dec 7, 2014
    Yep, exactly the place it snapped. I will post a pic shortly
  7. G72Zed
    G72Zed Veteran Member
    3,064
    1,530
    Sep 8, 2015
    I stand by my post (#2) and fully agree with Ratty_81 post.
    And one of the reasons why conical 1/2 breed coil over front shocks had issues.
  8. Lowend
    16,465
    1,262
    Mar 25, 1999
    San Jose, CA, USA
    For a time Hotchkis was contracting Bilstien to build them shocks specifically to use with the TVS kit. You couldn't buy the PN directly from Bilstein. They have since switched to Fox
  9. biker
    3,798
    1,793
    Dec 7, 2014
    Yes. At the time I bought the Bilsteins, my thinking was along those lines. They must have similar calving, and they did work well for a while.
    Anyways, I called Hotchkis and they said any shock they sell will work safely with up to 2" drop.
  10. biker
    3,798
    1,793
    Dec 7, 2014
    Just pulled the trigger on 4 Hotchkis (Fox) rebound adjustable gas shocks.
