Ignition switch mounting
Discussion in 'Troubleshooting & Diagnosis' started by Bigblockscott, Aug 3, 2020.
  1. Bigblockscott
    Bigblockscott Member
    38
    Feb 16, 2017
    Hey everyone, Over the weekend I took my steering column apart to clean and paint it.Factory 1970 column, non tilt, auto. When I began the disassembly process the ignition switch, mounted low on the column, was missing. Now I have everything back together and went to install a new ignition switch, Standard Motors Products #US95, but I am a little confused on how it is supposed to engage the rod coming from the key switch. My rod sticks straight out, I feel like it needs to be bent 90*, but when I try do that I feel like something is going to break. Can someone please enlighten me, hopefully with some pictures so I can figure out what I'm doing wrong.
  2. Green hornet
    Green hornet Veteran Member
    2,021
    470
    Oct 11, 2015
    North Bay, CA
    It kind of like a rubrics cube. Turn the switch so that the part with the red arrow is facing down on the column. The switch will fit over the rod. Do not bend the rod to try and make it fit. Hope this helps.
  3. Bigblockscott
    38
    Feb 16, 2017
    Green Hornet....Thanks, after I stepped back from it for a day or so I got it figured out.
