I'm ready to surrender to the LS world!
Discussion in 'High Tech Retrofits' started by dougs79Z28, May 29, 2012.
  1. dougs79Z28
    dougs79Z28 Veteran Member Lifetime Gold Member
    355
    Oct 26, 2010
    Nashville, TN
  2. THOMAS81Z
    THOMAS81Z Veteran Member
    3,172
    Sep 30, 2000
    new market NH
  3. dougs79Z28
    355
    Oct 26, 2010
    Nashville, TN
    Patrick G(from ls1tech and grrrr8.net board)spec'd out my set up for my stealth street car. I told him I wanted good vacuum with an idle of 750 followed by performance. Attached is the recipe. Will start pulling the intake and heads next week. Theya re pulling the LY6 out tomorrow! :) Still need to locate an oil pan.
    Doug
    {His response in email}
    On the attached sheet, please find your custom 222/230 .597/.609" 114LSA +4 camshaft recommendation. This profile features Endurance lobes on the intake from EPS for maximum power under the curve. These lobes are very stable at high rpm with a wide variety of valve springs. For the exhaust, I have chosen the all-new LXL lobes from Comp. These lobes are specifically made for sustained high rpm road race applications and they give outstanding control under boost and will have much less sewing machine noise than typical high-lift lobes. They are excellent in their high rpm stability and will give much better valve control than the popular XE-R, LSL, LSK, XFI lobes from Comp.
    To raise your compression from a stock 9.6:1 to 10.2: 1, I am recommending that you mill the heads .018" and use a thinner .040" Cometic head gasket. This will give you another 2% increase in hp and tq. You can order this cam and any other valvetrain components you wish (like springs, pushrods, timing set, etc.) from Geoff Skinner at Engine Power Systems. Any questions, please write back.
    Patrick Guerra - The Guerra Group - 114 Spokane Avenue - Victoria, Tx. 77904 - 361.576.5917 office - 361.576.5928 fax - 713.306.9990 cell - www.guerragroup.com
  4. Blown Camaro
    Blown Camaro American by birth, drag racer by choice
    1,199
    140
    Dec 13, 2009
    Deltona, FL
    I have had both a Gen 1 small block Camaro and an LS1 2000 T/A at the same time to cross compare them. These are my opinions only:
    Gen 1 > Sounds much better, looks better
    Gen 3 > Everything else! :)
  5. usmcz28
    usmcz28 Veteran Member Lifetime Gold Member
    382
    Jun 19, 2005
    Rochester, NY United States
    That 2000 T/A would be a 4th gen ;) unless we're talking engines then t gets into a grey area.
  6. dougs79Z28
    355
    Oct 26, 2010
    Nashville, TN
    Ok- so I'm ordering the vvt delete kit.
    >>GM Front Cover (Non VVT)
    >> GM Cam Sensor
    >> GM 3-Bolt Cam Sprocket
    >> ARP LS1 Cam Bolt Kit
    $128
    Should I get a new timing chain? ($42) or can/should I use the stock one?
  7. camarochevy1970
    camarochevy1970 Veteran Member
    7,859
    82
    Jan 23, 2003
    Pittsburgh, PA
    Should be able to use the stock one without much issue.
  8. dougs79Z28
    355
    Oct 26, 2010
    Nashville, TN
    Bought an ly6 w/ 26k miles on it! On the trailer to the house!
  9. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Congratulations.
    Just out of curiousity, how much did it run you and what came with it ???
    I'm dying to see if mine is a gas pig or not. :eek:
  10. dougs79Z28
    355
    Oct 26, 2010
    Nashville, TN
    If you don't like photo's- don't follow this thread! lol Breaking it down.
