Incorrect Idler Arm
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by thumbdoctor, Aug 27, 2020.
  1. thumbdoctor
    thumbdoctor Member
    33
    18
    Jun 24, 2016
    St-Lazare, QC.
    Quite common on base Camaros (6 Cylinder) 70-71 Z28s had them, no tilt column available with this box thought. too hard on the steering shaft. A real workout with wide sticky tires.
  2. thumbdoctor
    thumbdoctor Member
    33
    18
    Jun 24, 2016
    St-Lazare, QC.
    After exhaustive research, I now realize that I have the incorrect pitman arm. The manual "Quick Ratio" utilizes a longer pitman arm with "M" stamped into it at the splined end. Most share the same casting number but the power steering model has a larger diameter pitman shaft and a "P" stamp. Somehow I have a 6 cylinder manual steering pitman arm. the steering box is the correct 54679142 Quick ratio unit. Now the search for the correct arm commences.
  3. 70lt1z28
    4,400
    1,041
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Yes, correct. See post 5. Not sure if anyone is repoping the manual pitman arm. Doubt it. One problem with the pitman arm search is it has the same casting number as the far more common power steering arm so you see many of those on eBay etc. Lots of dead ends. The M is not always stamped very well. Might want to reach out to Rick Griffin ricks72z28 or tommyrsz28. I think Rick may have sold his last one to Mulsanne Blue.
  4. BonzoHansen
    20,811
    1,835
    Jun 1, 2005
    Scott from Hamilton, NJ
    No, on a 2nd gen a ptman arm isn't a wear item, unless maybe it gets damaged buy the box nut or center link nut coming loose. I don't consider that wear, it's damage. not sure I ever saw that in my years in the shop. I've certainly never seen a bad one on a 2nd gen. The center link, tie rods and idler sure, they have joints.
    1st gens have pitmans that wear because the joint is in the pitman arm. My k1500 is the same way.
  5. Rosster
    Rosster Veteran Member Gold Member
    607
    309
    Mar 1, 2020
    Both my 70 z-28s had manual steering
  6. 70lt1z28
    4,400
    1,041
    Oct 3, 1999
    First I've heard that a Z28 with manual steering couldn't have a tilt wheel. Do you have a GM source document for this?
  7. Zclassic
    Zclassic Veteran Member Lifetime Gold Member
    574
    May 28, 2002
    Walnut Hill, Florida
    Thumbdoctor- I have a few NOS manual steering centerlinks if you want to get your steering geometry correct while your searching for the correct pitman arm. Send me a PM if you or anyone else reading this needs one. Thanks
  8. Get' er Done
    Get' er Done New Member
    Dec 5, 2012
    Western, Ma
    Not sure if this is the one your looking for. https://www.camarocentral.com/1970_1981_Pitman_Arm_Manual_Steering_p/sus-283.htm
  9. thumbdoctor
    thumbdoctor Member
    33
    18
    Jun 24, 2016
    St-Lazare, QC.
  10. thumbdoctor
    thumbdoctor Member
    33
    18
    Jun 24, 2016
    St-Lazare, QC.
    When I ordered my 1970 Z28 from our dealership, the guide stated that option N33 was not available with manual steering and M22 due to the reverse gear lock out. I have since seen a few Z's with P/S with M22 but cannot be sure if they're original equipment.
