1934chevycoupe
So got hooked on Hot Rod Engine Masters on cable, and one of the shows this weekend was about using a dyno to breakin a new engine. I have a GMPP LS3 w/ the hot cam, which apparently is not all that hot. Anyway, one thing they mentioned was that if you're going to install coated headers, that you should initially install old headers or manifolds to breakin the engine, and then install your coated headers after everything is all adjusted and running right. Otherwise, you nay have bubbles in the coating or i guess they turn an ugly color. The engine came w/ manifolds i can put on, and i'm not sure if you'd run a short pipe and maybe run it into some mufflers or not. I know the neighbors would go for the mufflers. Anyone here start off w/ a new LS never run, and hooked up to your shiny new headers for the initial breakin? Experiences? Thanks
