Instrument cluster
Discussion in 'Electrical Systems' started by dgg81z, Sep 15, 2021.
  1. dgg81z
    dgg81z New Member Gold Member
    22
    Apr 2, 2008
    Memphis,Tn
    I have 81 Z28. Car has a total Kwik Wire harness from front to back top to bottom. Problem is the person that was hired to do job died before completion. Most things seems to be working as they should but I'm wondering I can not seem to locate the ground wire for the instrument cluster. I'm fairly certain there should be, surly if there's not one I could one one but where would a safe to put one. My email: [email protected] Thanks
  2. Twisted_Metal
    29,962
    2,715
    The ground is handled through the cluster plug.
    It's the black one in the corner.
    It doesn't matter whether it's an "idiot light" cluster of gauges... The ground wire is in the same place.
    What circuits don't work?
  3. dgg81z
    22
    Apr 2, 2008
    Memphis,Tn
    they all appear to be working just not sure if properly especially temp gauge. Have flushed rad, prestone 50/50 mix, high flow 180 stant thermostat water pump has a 4 row aluminum rad with dual elec cooling fans replaced temp gauge sensor today. Drive 3-5 miles gauage almost in the red. The car has no factory wiring left in it all KWIK wire
  4. Twisted_Metal
    29,962
    2,715
    Sounds like a potential mismatch between your gauge and sending unit.
    Is it a factory gauge cluster?
    If so... What year car is the temp gauge? (There were different sending units used through the 2nd gen years.)
    Have you confirmed with an infrared temp reader that your engine is getting that hot?
    Snoots and hubedobeedo like this.
  5. dgg81z
    22
    Apr 2, 2008
    Memphis,Tn
    factory gauge cluster, not sure its the original factory gauge when I bought the car. Same gauge when I had a different engine in the car, when I restored the first time. No infrared.guess I could buy one approx cost or you suggest a brand.
  6. Twisted_Metal
    29,962
    2,715
    The temp guns are probably all made in China so I don't know what brand would be good.
    You can get a temp gun at your local Harbor Freight store for about $20-25.
  7. dgg81z
    22
    Apr 2, 2008
    Memphis,Tn
    Thanks getting one this morning
  8. dgg81z
    22
    Apr 2, 2008
    Memphis,Tn
    Got reader home depot haven't had chance to try it hopefully tomorrow trying to finish wife's wheel chair ramp.
    MChamp likes this.
  9. MChamp
    MChamp Veteran Member
    222
    61
    Jun 6, 2021
    north carolina
    please let us know how you like it and which one if you would. I'm looking at getting one. thanks and best wishes!
    dgg81z likes this.
  10. MP81
    MP81 Veteran Member
    463
    39
    Oct 10, 2016
    Washington Township, MI
    Are the fans on a temp sensor switch so they turn on at a desired temp? If so, are they kicking on? And if that's the case - are they turning/oriented the right direction?
