intake manifold research info:
stinkboy
883
milton, florida
after looking at an intake change out, i decided to put my research down in here where it might get some use. im sure im missing some crap.
Edlebrock Manifolds:
Performer 2101 dual plane
action: idle to 5500 rpm
height: front 3.74" rear 4.80"
gasket: eddy 7201 or fel pro 1256
Performer Air Gap dual plane
height: front 3.72 rear 4.92 this is .27"(1/4") higher than 2101
gasket: eddy 7201
Performer RPM and RPM Air Gap dual plane 7100 series rpm 7500 series rpm air gap
action: 1500 to 6500 rpm
height: front 4.20 rear 5.25
gasket: eddy 7201 and fel pro 1205
Torker single plane
action: 2500 to 6500
height:
gasket:
Torker II single plane
action: 3500 to 7500 rpm
height: front 3.53 rear 4.63
Victor Jr single plane
action: 3500 to 8000
height: varies use eddy website
gasket: eddy 7217 and fel pro 1205
Victor Jr High Port single plane
action: 4000 to 8000
gasket: eddy 7217 and fel pro 1263
Victor Jr Bowtie II single plane also has a tall version 1" taller
gasket : eddy 7206 or 7217 and fel pro 1206
Weiand Manifolds:
Weiand Action + Plus dual plane
action: idle to 6000
height: front 3.75 rear 4.63
gasket: fel pro 1240
Weiand Stealth dual plane 8150 series
action: 1500 to 6700
height: 4.73
gasket: Mr. Gasket 5821 and fel pro 1205
Weiand Steal Air Strike dual plane
height: front 4.19 rear 5.27
gasket: fel pro 1204 and 1205
Weiand Xclerator single plane
action: 2000 to 6500
height: front 3.09 rear 4.06
Weiand Team G part #7530 single plane
action: 2800 to 7800
height: front 4.38 rear 5.31
gasket: fel pro 1205 and 1206
Weiand Team G part #7531 single plane
action: 3000 to 8200
height: front 5.63 rear 6.56
gasket: fel pro 1205 or 1206
Weiand Team G part #7532 single plane
stinkboy
883
milton, florida
my research also found:
dual plane: low end torque, lose a little at top high HP
use dual for street/strip where the max rpm is 6500 or lower
single plane: lose a little low end torque but gain some high end HP
use single for street/strip where the max rpm is over 6500 or the converter stall is 3K or higher.
fun79Z28
337
Richmond, MI
dart intakes
Just a lil sidenote:
Have you looked at the Dart Iron Eagle intake manifold? I was looking for an intake to better match my heads (Iron eagle 200cc) and was thinking about going wiht that one, but was hopin to compare it to the edelbrocks as i liked those as well!
stinkboy
883
milton, florida
80'427 said:
You do know there are 3 team G intakes right
i cant do all your research for you. if you are interested in the G intake im sure that person will do their own research. if not then they get what they get.
this is just a little summary for those that actually use the search function. its also nice to know the height changes and what rpms each intake is SUPPOSED to handle.
but thanks for the pat on the back.
80'427
1,886
Fairbury, NE, USA
Its great info I just was saying. Sorry. I spent DAYS looking for a intake shorter than 3.75 at the front for a circle track class that had that limit. Thats why I know. The shortest is 3.50".
23,821
Gallatin Tennessee
what about these edelbrock intakes :
edelbrock torker single plane intake 2500-6500rpm
edelbrock TM-1 single plane intake 3500-7500 rpm
edelbrock scorpion single plane intake 4000 -7500rpm
edelbrock TR1-X tunnel ram 4500-8500rpm
Damon
12,939
Philly area
You should have just asked for a copy of my spreadsheet! It's got all those intakes and and specs plus more, but no gasket recommendations.
ZS10
Moderator
12,166
BC, Canada
Or just looked up the thread with all the info from the magazine test article.
What do you have now? Curious at to why you think you need a new one.
