INTAKE MANIFOLD SANDBLASTING
Discussion in 'Engine Topic' started by wnmech, May 11, 2021.
  1. Bandit723
    Bandit723 Veteran Member
    3,665
    677
    Oct 1, 2016
    Waupaca WI
    not sure why a motorcycle shop would have technology that no one else has. Vapor blasting vs wet blasting to me seems to be the same thing.
  2. Rosster
    Rosster Veteran Member Gold Member
    607
    309
    Mar 1, 2020
    Mine looked perfectly clean as well- until I took it apart. I’d highly advise against skipping this step. It’s a 5 min job to remove the metal cover, 2 mins to reinstall, and rivets are $5. Sand blast grit will stick to any little spec of oil or sludge and eventually be released into the engine oil. The only way to verify it’s 100% clean is to remove the cover.
  3. Rosster
    607
    309
    Mar 1, 2020
    They are one in the same. In my mind wet blasting seems more accurate but for some reason around here many shops use the vapor blasting term.
  4. tom3
    tom3 Veteran Member
    13,610
    1,131
    Aug 1, 1999
    ohio
    I would blast an intake with any kind of abrasive material. Just one piece of grit left on or in it and the engine is ruined. I use liquid cleaners, brushes, and have used battery acid to get the white cast finish on a couple.
  5. Rosster
    607
    309
    Mar 1, 2020
    I’ve done a bunch with zero problems. I always high pressure water blast them afterwards and always remove the heat shield underneath to ensure they are spotless. The wet blasting tends to leave less potential for grit as it tends to polish the finish vs. embed media
  6. Bandit723
    3,665
    677
    Oct 1, 2016
    Waupaca WI
    Well you can blast these things with whatever you like it's ok. it's look may come into play dull vs factory look. just saying
  7. Rosster
    607
    309
    Mar 1, 2020
    my go to on factory cast parts is water (vapor) blasting. Parts come out stunningly like brand new. Here’s the same part glass beaded vs water blasted.
    BD1EA363-628C-486D-BCE3-27D6A822B21F.jpeg EB85E7D6-13C8-48D0-8304-E56883048C3C.jpeg
  8. wnmech
    wnmech Veteran Member
    1,325
    279
    Jul 20, 2014
    grand prairie tx.
    Looking at the pictures that Rosster just posted which look most resembles what the manifold looked like when they were factory installed on these cars. When I received my kit car my manifold looked like the one on the left side with the flat aluminum look.
  9. ChevyReb
    4,348
    224
    Feb 4, 2003
    SC
    View attachment 119423 20210322_212113.jpg 20210322_212055.jpg 20210322_212016.jpg Here one I glass beaded and then used a brass wire brush on after removing powdercoating.
  10. Bentley
    Bentley Veteran Member
    120
    59
    Aug 14, 2020
    Perhaps your not aware of how much people spend on there Harleys??
    Rosster and ChevyReb like this.
