Intake suggestions
Discussion in 'High Performance Modifications' started by HULKZ28, May 28, 2015.
  1. 1980RS
    1980RS Veteran Member
    5,065
    1,564
    Jun 17, 2006
    MN
    I ran a Super Victor this year 2975 after spending the winter porting it. It made so much bottom end tq. I thought I had a dual plane on it. The only problem was the top end performance still sucked compared to my 300-25 that I will use again. The Hurricane intake worked well but the Holley is the winner in my book. These tests were all with a homemade 750hp and my 850 Mighty Demon.
  2. HULKZ28
    HULKZ28 Veteran Member
    1,572
    Oct 15, 2005
    Jeffersonville NY USA
  3. HULKZ28
    1,572
    Oct 15, 2005
    pretty sure ill go with the strip dominator,thanks guys.
  4. muscl car
    23,142
    1,618
    Jul 8, 2001
    SoCal High Desert
    Good choice !!! , I've had a date coded 9-7-75 Winters foundry stamped Strip Dominator on my sbc since early 2010 and very happy with it !!
  5. Rich Schmidt
    Rich Schmidt Veteran Member
    4,284
    40
    Mar 27, 2010
    Denville NJ
    The cam you have is what will make your engine soft below 4500. If I built that combo,I would be running a 4500-5000 stall convert or anyway. Even with the largest intake,you wont loose anything below about 3500 rpm anyhow. The combo you have should be leaving at no less then 4800 and shifting at about 6700 for best e.t.'s,so you pretty much determined the entire combo when you chose that cam.
  6. HULKZ28
    1,572
    Oct 15, 2005
    My cam specs were slightly off..it's a Herbert c6kf.3000-7000 range. 108 LSA. .251/[email protected] .508/.625 lift..
  7. rally
    rally Member
    33
    Nov 30, 2014
    ohio
    Yes the 67-69 Z-28 302 Factory Intake was a great design and can still run with the new technology intakes of today.
  8. Mike-78 Z-28
    Mike-78 Z-28 Veteran Member
    1,909
    Mar 4, 2003
    ElDorado Arkansas
  9. HULKZ28
    1,572
    Oct 15, 2005
    great video,but how many rpms do u think that engine can pull with that intake?? I would think a strip dominator would take the same motor to a much higher rpm ? I would port my rpm intake and save some $$ IF I thought it would fit my engine combo..run 6500 rpms ,at least.
  10. muscl car
    23,142
    1,618
    Jul 8, 2001
    SoCal High Desert
    Nelson racing engines builds awesome but crazy expensive engines . I read somewhere that the motor in that Camaro would easily see 7k rpm
