interior dome light randomly turning on
Discussion in 'Troubleshooting & Diagnosis' started by cordero51, Oct 31, 2017.
  1. cordero51
    cordero51 Member
    38
    Apr 11, 2015
    el paso, texas
    this popped up a few nights ago but my interior dome light kept turning on when i was driving, it would turn on for a few secounds an then turn off it didnt seem to go on cause of bumps and im pretty sure the doors were secured... i just replaced the headlight switch not too long ago and had some rewiring done for my electric fuel pump. does this mean i have a short? and were should i look to see what is causing it to go off
  2. hogg
    hogg Veteran Member
    3,179
    29
    Dec 29, 2000
    pegram,tn.,cheatam
    Power is at dome lite at all times, comes on when there is a ground. I would check at lite switch to make sure dome lite switch isn't turned ,about, on there, then move to the door switches to see if one has wire off or out of adjustment. you may also have curisty under dash lites. harbor fright has a cheap probe red or green lit depending witch way the cruet is going, helps to find shorts.
