Tokyo Torquer3
Guys,
Any of you know if the intermediate steering shaft for 1973 camaro tilt and non-tilt steering columns are different? I did a thorough archive search and could not get clarity on this.
My original non-tilt steering column and shaft has the column to pot joint coupling bolt going vertical at the 3 o'clock position. That is, the recessed groove cut in the end of the splined column shaft for the coupling bolt is in the 3 o'clock position from the driver seat perspective.
I just got a rebuilt tilt column from NPD that looks correct in every way, except now the groove in the splined end of the column is in the 12 o'clock position (coupling bolt would be horizontal in the 12 o'clock straight ahead position).
I also just bought a new OEM replacement intermediate steering shaft that is supposed to fit all 70-early 78 power and manual steering Camaros, and it did not mention any distinction between tilt or non-tilt steering columns. However, the coupling bolt on the pot joint end is oriented 90 degrees different from my original intermediate steering shaft. This should work good with the new tilt column. However, I want to confirm that there are different intermediate steering shafts for early 2nd gen tilt and non-tilt steering columns.
mike
mike
